Old 07-31-2009, 12:09 PM   #1
Zabo
Gunning for Sixth
Zabo's Avatar
Drives: '03 ZR2 Blazer
Tight steering on a '99?
Just test drove my possible future Fbody steed and noticed aside from the lolpowerwindowmotorgoingout thing that's common to these cars that the steering felt a bit tight. Much more so than my relatively loose Explorer. I'm wondering if it's the Powersteering motor/pump starting to kick out or if it's just the nature of the car.
I'll have a second opinion on the car if we do pick it up when my dad takes it for a spin after a long 20+ year absence from a camaro cockpit. Just wanted to get the word from the other owners out there as to what this could mean.
Zabo is offline   Reply With Quote
Old 07-31-2009, 12:34 PM   #2
Blownhotrodder
Blownhotrodder's Avatar
Drives: 2018 ZL1 1LE
What do you mean by tight? My 2000 has very touchy steering, by that I mean you have to put in very little input to change direction.
Blownhotrodder is offline   Reply With Quote
Old 07-31-2009, 12:39 PM   #3
Zabo
Gunning for Sixth
Zabo's Avatar
Talked to Hylton and he has similar issues. It seems that the power steering motor is just old. Not that old, but yeah. Still drives fine, it's just sluggish. I'll replace it probably in Feb/March if I do get it as a post grad project along with the power window motors.
Old 07-31-2009, 04:51 PM   #4
Super83Z
Super83Z's Avatar
Drives: 1999 Z28 1983 Z28
Does the steering wheel turn smoothly? Fords have exceptionally light steering. The 4th gen Camaros have more of a stronger resistance when turning the wheel. I noticed a difference in resistance going from a 245/55/16 to a 275/45/17 up front.
Current cars:
99 Z28
06 Silverado
14 Silverado
Super83Z is offline   Reply With Quote
Old 07-31-2009, 05:14 PM   #5
Zabo
Gunning for Sixth
Zabo's Avatar
Yeah, it turned smoothly but was just..tight. Like someone was holding it while I turned it with one hand. 2 handed it was fine, felt like the Explorer, so may be I have to do some curls. That could be it.. I'm just used to Ford steering.
I mean a symptom of a bad pump would be clunky steering, right?
Old 07-31-2009, 05:17 PM   #6
Super83Z
Super83Z's Avatar
I'm not saying that the pump is def not the problem, but usually there isn't a middle ground with a PS pump. Usually it works or doesn't, or it spews fluid or it doesn't.
Current cars:
99 Z28
06 Silverado
14 Silverado
Old 07-31-2009, 05:26 PM   #7
Zabo
Gunning for Sixth
Zabo's Avatar
So no warning, just.. no steering one morning and PS fluid-puke on the ground under the car.
Old 07-31-2009, 11:18 PM   #8
Super83Z
Super83Z's Avatar
Well usually its leaking and making ungodly noises long before it stops working. Thats usually when it gets changed out.
Current cars:
99 Z28
06 Silverado
14 Silverado
Old 08-01-2009, 06:20 PM   #9
Zabo
Gunning for Sixth
Zabo's Avatar
Oh.. well that's about $200.00-4K that I'm going to be saving on the car in the long run. Not a drop under it when I moved it and parked it.
steering wheels Broncos78 5th Gen Camaro SS LS LT General Discussions 1 07-31-2009 02:05 PM
Steering wheel controls Timberline Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 3 06-05-2009 09:39 AM
Steering wheel and shifter material? Blacked Out 5th Gen Camaro SS LS LT General Discussions 13 05-20-2009 02:34 PM
Steering Feel stovt001 5th Gen Camaro SS LS LT General Discussions 15 01-25-2009 03:14 PM
Power Steering - hydraulic or electronic steering? balonywolf 5th Gen Camaro SS LS LT General Discussions 20 02-28-2008 11:01 PM
