Old 04-04-2014, 11:05 AM   #1
ytown87
ytown87's Avatar
Drives: C6 Corvette
What final gear are you in? 1/4...M6 SS
Last night I got 4 runs in. 1st run went through and shifted at 6000 to 4th. 2nd run I got the notorious clutch sticking to the floor at launch and had to nurse it down the lane. 3rd run I said heck with it ima leave it in 3rd but hit the limiter maybe 50-75 ft from the 1/4 and dropped off. 4th run I shifted to 4th around 6200 and right as I left off the clutch there was maybe that 50 ft left.
Is this normal? It feels like I'm losing speed in that last few feet for no reason. I hang every gear to right at the limiter. Since I'm fairly new to drag racing I wanted to make sure I'm doing things right and not scrubbing off lower times. Personal best so far 12.763 1/4 and 2.015 60' on stock pirelli which are almost done for. Will be switching to 305 nitto 555r real soon.
Mods:
BBK LT headers
Cat delete
CAI
Borla Attack axle back
Cutouts
Custom dyno tune
430whp 430tq
ytown87 is offline   Reply With Quote
Old 04-04-2014, 11:28 AM   #2
Juice2SS
Drives: 2011 2SS
You need more gear. I could run some calculations but a 3.73-3.91 would probably have you at redline in fourth at the stripe. Not sure which one though. I know the 1LE guys are going through at the top of fourth if that tells you anything.
Juice2SS is offline   Reply With Quote
Old 04-04-2014, 04:01 PM   #3
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
If your car is tuned you need them to raise the limiter! When I have my m6 I always hung out 3rd till the end. If your shifting 4 your loosing speed, have them raise it to 7k. I use to cross the traps around 6800 if I remember right. This is your only option, and your motor will be fine.
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 04-04-2014, 04:28 PM   #4
ytown87
ytown87's Avatar
Drives: C6 Corvette
I was thinking going this route as well but not sure how much it is to put in 3.91 gears. Any idea?
Think I may also have the limiter increased for now as a temp solution. The power band on the dyno started to drop off around 6100 bit it'd be worth it not to shift again and scrub speed.
Talked to a few guys and I think I may do so drag shocks in the back and remove the front sway bar to hook better.
Old 04-05-2014, 03:03 AM   #5
2010SSRSM6
2010SSRSM6's Avatar
Finding 3.91's is going to be harder than finding a shop to install them. I've seen anywhere from $500-850 to install gears, plus the cost of the gears and the install kit.
If you are thinking gears, you might as well install a TruTrac and axles while they are in there.
Old 04-05-2014, 10:00 AM   #6
Irnwkrkev
Irnwkrkev's Avatar
Drives: 2011 SS/RS LS3
4.30's would put a bolt-on 6m closer to redline @ the stripe. Liberty Gear is very reasonable to set up gears @ $350 + shipping.
Irnwkrkev is offline   Reply With Quote
Old 04-09-2014, 11:07 PM   #7
SannerRacing
SannerRacing's Avatar
Drives: 2010 1SS RS IOM
I'm running 3.89s in mine and the rev limiter is set at 7100 and I have to use 4th. Before the gear change with the rev limiter the same it hit right at the finish line in 3rd. I tried short shifting and using 4th with no ET gain.
Forged LS3 416ci, Maggie TVS2300 @ 13lbs boost, McCleod twin disc clutch, GForce 1320 nine-inch 389 gear ratio, Hurst line-lock, 750 whp 700 wtq
SannerRacing is offline   Reply With Quote
Old 04-12-2014, 01:11 PM   #8
KPowers
Drives: none
I hit the traps on the limiter in 3rd. Literally as soon as I hit the line the limiter kicks in. I've tried hitting 4th but like you I felt I was losing speed. I am racing at Bristol TN which is up hill and crazy elevation but I managed a PB of 13.34 @ 110.9 on LT headers, cat delete and the NPP exhaust open. No tune on stock Pirelli tires.
KPowers is offline   Reply With Quote
Old 04-13-2014, 09:43 AM   #9
Rabamaro
Drives: 2010 ABM SS/RS
At 430 whp, you won't come near the limiter with 3.91s. 4th gear tops out at 140 mph with the 3.91s. Also putting in $1200 axles seems overkill. I got my 3.91s from Maureen at Rogers Chevy for $254 shipped and had my dealer install the gears and posi mod for $600. I drove in and drove out 2 days later. They're even warrantying it since it's a GM part and they did the install. I broke a stock axle 3 weeks ago, and they didn't blink twice to warranty it. I'm at 498 rwhp currently.
Vararam Tune CAI, Vararam Power Wedge, 160 degree stat, VMax ported throttle body, Ceramic coated ARH 1 7/8" LTs with X-pipe, Borla S-Type Axle back, MGW short throw, 3.91s, Ported stock IM, BTR Stage IV cam, Heritage Grille, Backup camera, UMI Performance trailing arms and toe rods, dyno tune
Rabamaro is offline   Reply With Quote
Old 04-19-2014, 06:54 AM   #10
viper2183
Tampa Bay Camaros
viper2183's Avatar
Drives: 2012 Camaro SS 45th Anniv. Edition
I hit the limiter at 6500 just as I cross the traps in 3rd. Stock 3:45 gears, tune, shorty headers, hi flow cats. Was thinking about going to 3:91 or 3:73, but first have to be consistent on launches stick is hard to launch.
Thanks,
Dan B
viper2183 is offline   Reply With Quote
Old 04-19-2014, 09:14 AM   #11
Merc
In The Circle
Merc's Avatar
With the 345's I crossed the stripe at the top of 3rd gear and went 12:30's. With the 391' I launched Pumpkin at 4800 on a Lingenfelter 2Step go 1.60's 60 foots and 11.90's at the big end shifting to 4th a few hundred feet from the stripe. 410's now but have yet to run them.
Old 04-19-2014, 09:21 AM   #12
Suprslo
Drives: 2013 SS
I cross the traps in 4th gear just before redline. I have 391s and just over 700 rwhp. I'm trapping 131-132. Hope this helps?
Suprslo is offline   Reply With Quote
Old 04-29-2014, 12:48 AM   #13
chalhoee
chalhoee's Avatar
Drives: 2010 M6 2SS/RS
440whp here on stock diff M6 and I pass the finish line right at the top of third. Best time so far has been a 12.7 @ 117 on some 555's. Hope this helps
SW 2010 2SS/RS
Currently at 608whp/701tq
-229/236 CAM-VR-BBK LT's-Vmaxx TB-O/F Xpipe-LM2's
-LS3 ported heads/Mani
-Wet Nozzle 150 shot
-Tuned by Solid Tech Performance (ABQ, NM)
chalhoee is offline   Reply With Quote
Old 04-29-2014, 07:10 AM   #14
ytown87
ytown87's Avatar
Drives: C6 Corvette
Last time I went I was able to pull a 12.685 @111. I stayed in 3rd but held the throttle right at 6400 rpm instead of shifting or hitting the limiter. Was pretty happy with that time. Still had stock worn pirellis and stock gears.
