Old 04-04-2014, 05:07 PM   #1
Berje
Berje's Avatar
Drives: 1994 z28, 2010 ss, 2010 titan
Relocating Positive battery terminal
I saw this http://www.camaro5.com/forums/showpo...&postcount=245 but was wondering if anyone had a more detailed DIY on it.
Berje is offline   Reply With Quote
Old 04-04-2014, 07:48 PM   #2
Berje
Berje's Avatar
anyone?
Old 04-04-2014, 11:25 PM   #3
gisbert.j.hanft
Drives: 2SS Transformer Eddition 2012
I don't have pictures. But here are the steps
Disconnect negative terminal on battery
Take red part off under the hood
Unscrew battery terminal
that is going to Give you the red positive cable and the black cable it is original connected to
Now Jack the car up and remove the plastic rock skiirt should be few Alan head screws
now look where the positive cable is coming from. You still see s few empty holes feed it through the one closest to the outside of the car.
You will see it coming down by the wheel
now take the black cable and run under the frame
your going to need to buy a small screw and nut to reconnect the black wire to the red and shrink wrap.
Just connect wires shrink wrap it and reinstall your skirt and connect negitive
gisbert.j.hanft is offline   Reply With Quote
Old 04-05-2014, 10:52 AM   #4
Berje
Berje's Avatar
okay, thank you!
