Old 04-04-2014, 08:30 PM   #1
The_Blur
Moderator
The_Blur's Avatar
FE3-ZL1 Sway Conversion Advice
I have access to a set of ZL1 sway bars for my 2011 Camaro SS. I have to do a conversion to the FE4 setup to make this work, so I'd like to put together a complete parts list and any firsthand advice for this. Your help is appreciated!
I'll post pics and progress when this goes down in my Blur SS build journal.
The parts list (brands) so far:
  • 25mm front sway (Chevrolet, ZL1)
  • 28mm rear sway (Chevrolet, ZL1)
  • front and rear bushings (Chevrolet Z/28 or aftermarket)
  • 2012+ front and rear end links (Chevrolet, SS or ZL1)
  • updated rear lower control arms (Chevrolet, SS or ZL1)
warn 145:159 ban
Old 04-04-2014, 10:31 PM   #2
Macfolk
J.T.
Macfolk's Avatar
Drives: Camaro 2SS w/RS package, Imp. Blue
Subscribed.
2011 Camaro 2SS/RS L99
Mods done: 1LE replica wheels, black tail light bezels, LED driving lights (spliced to running lights), VMax CNC ported TB, No tune Vararam, and Rx catch can
Mods planned: heritage grille, 1LE splitter, led signals, tune, and possibly LT Headers
Love this car!
Macfolk is offline   Reply With Quote
Old 04-04-2014, 11:21 PM   #3
enyce0387
enyce0387's Avatar
Drives: 2011 camaro 2ss/rs ls3
dooo itttt!! i did it a while ago got a package from pedders. I think all you really need is new lca's the new zl1 bars new rear end links and front end links.
enyce0387 is offline   Reply With Quote
Old 04-05-2014, 03:30 AM   #4
Jerry7297
Jerry7297's Avatar
Drives: 2018 2SS/ 1LE
Your list looks good. DO it and dont look back. I have the PFADT ZL spec set up on mine and it totally changed the body roll situation. Do the bushings when you are doing it you will have everything apart anyways. GOOD mod highly suggest this FE4 rocks...
Not sure what all you want to improve but Subframes, toes, and trailing arms w/ bushing also kicks butt to install. You can actually put power to the ground. Good luck with your install.
Jerry7297 is offline   Reply With Quote
Old 04-05-2014, 08:47 AM   #5
The_Blur
Moderator
The_Blur's Avatar
Did you do these installs yourself? Was this a 1-man job or is this something that will require me to find some help?
warn 145:159 ban
Old 04-05-2014, 11:17 AM   #6
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Suspension Help
Should be able to do it all yourself the wife can lend moral support every now and then an be the beer assistant
Old 04-05-2014, 12:10 PM   #7
The_Blur
Moderator
The_Blur's Avatar
I like that kind of support. Unfortunately, I can't drink at the auto hobby shop on base. That's where I've done all my work thus far. Lifts and unlimited tools cost $5/hour.
warn 145:159 ban
Old 04-05-2014, 12:11 PM   #8
Macfolk
J.T.
Macfolk's Avatar
"Lifts and unlimited tools cost $5/hour."
That's a perk!
Love this car!
Old 04-05-2014, 01:17 PM   #9
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
We got the same setup here at Ft Campbell an last i heard they had a lot of snap on tools
Old 04-05-2014, 03:54 PM   #10
Jerry7297
Jerry7297's Avatar
Can be a one man job. I did do my front sway and end links by myself. When I did the back I also did the sub frame bushings and had some help. It is possible to do it by yourself just easier with a buddy.
Old 04-05-2014, 09:00 PM   #11
heymatt
heymatt's Avatar
Drives: 2012 IBM 2SS Vert.
Don't forget the front sway links. You will have to enlarge the mounting hole on the strut. It is a one man job. Rear sway is easy, front is a lot harder.
I read that you can roll the sway bar out on the front. Couldn't do that so I disconnect the arms, not sure if that is the right term. But they are fixed length, so it was easy to put them back. Had all the room I needed at that point.
LS3/M6 K&N, VMAX throttle body, RX Catch Can, skip shift eliminator, DT shorties and Solo HFC, DRL harness and 5K LED DRL, ZL1 rear sway, 1LE front sway
heymatt is offline   Reply With Quote
Old 04-06-2014, 02:37 PM   #12
danvillekidd
2013 ZL1
danvillekidd's Avatar
Drives: 2013 ZL1 m6
Looks like you have everything you NEED, new sways, links, bushings and RLCA. The Auto Hobby shop is a nice perk, I used the one here for all of my bushings on the SS, so I could have access to the hydraulic press and specialty tools I don't own. I didn't bother driving there for the sways, just did them in my garage. One person job.
danvillekidd is offline   Reply With Quote
Old 04-17-2014, 12:58 PM   #13
Macfolk
J.T.
Macfolk's Avatar
What do these run pricewise?
Is there a benefit to buying ZL1 versus SS? I have a line on the sways and LCAs and hope to purchase within a week from another member.
Thanks!
Jason
Love this car!
Old 04-17-2014, 01:17 PM   #14
caverman
caverman's Avatar
Drives: '69 SS Convertible
It can be done with a one man job but always helps to have an extra set of hands. I did mine pretty much all by myself. My dad was around working on another car and every now and then he gave a hand to make things easier but wasn't required.
For the front sway bar, loosen the bolts and lift the motor and it should come out fairly easy.
When installing the rear drop links put the nut on the top. I did my bolt to where the nut was put on from underneath the LCA and it wasn't a problem until I put some 18" wheels on. The bolt ended up digging into the wheel. That was fun getting the car back up and then I had to cut the threads.
http://www.camaro5.com/forums/showthread.php?t=335907
Be ready to go straight to an alignment shop. My car drove all crooked until it was aligned. I think I was only comfortable to get it up to about 40 mph. The back end was all squirely and made for a real interesting drive to the shop. I had to go about 20 miles. Get you some Aggressive Street specs while you're at it.
Locktite (blue) everything you can. I had a front drop link nut come off which was a left thread and wasn't easy to find. I also had a bolt from the rear drop link come off and it caused the drop link to get jammed up in my control arm. I didn't locktite them initially but they are now.
If you're going to add toe rods, now would be the time to do it. Trailing arms as well but those don't require an alignment. Justice Pete said the stock ZL1 TA and TR were pretty good stuff but I don't know their prices compared to say BMR or Sphon.
Build Journal
