Old 04-05-2014, 04:44 PM   #1
charles s
charles s's Avatar
Drives: 2011 camaro 2ss
battery issue need help
hey guys and gals so I brought my 2011 ss to the shop to get a dent out. anyway long story short the dent was fixed and the gm dealer did an excellent job anyways, here is where the problem starts the first time it happened I was in a parking lot I turned the car off went in came back out tried to unlock it with the key and nothing so I thought hmm weird I manually unlocked tried to start it. It seemed to something then just nothing. so I fiddled around (yes the right key) turned the steering wheel and checked to make sure it was fully seated in park but nothing so I climbed into the back opened the truck and checked the battery as soon as I opened the shield for the battery power came back on. now I have had this happen a few times, the worst of all when I was driving home from the store today it shorted out mid drive and did like a weird reboot, the car never tuned off tho just all electrical stuff. so what is your guys thoughts I am stumped, hopefully its not a battery wire shorting or maybe its not attached properly I could take it out and put it back in I suppose ill go so that now.
charles s is offline   Reply With Quote
Old 04-05-2014, 04:59 PM   #2
Squillo
Drives: 2013 Camaro 2SS/RS BRM LS3
If I'm deciphering what you wrote correctly, it sounds like you may just have a loose connection on a battery terminal.
Squillo is offline   Reply With Quote
Old 04-05-2014, 05:02 PM   #3
charles s
charles s's Avatar
that what I thought also and I have taken the battery out and put it back in. same thing happened
Old 04-06-2014, 04:11 AM   #4
charles s
charles s's Avatar
yea and again when I was driving home tonight it flickered on and off the dash lights, as well it wouldn't roll up the window until I shut it off and rolled the up with power off
what do you guys think?
Old 04-06-2014, 07:21 AM   #5
6bangerBOOM
6bangerBOOM's Avatar
Drives: 2016 1SS SW
Have you installed any modifications that may be interrupting the power? If the vehicle is doing this while driving it could possibly be an alternator issue. Either way I'd take the battery to car parts store that can run a check for you. Sounds like you've picked up quite the gremlin. Hope you get it figured out soon!
6bangerBOOM is offline   Reply With Quote
Old 04-06-2014, 09:16 AM   #6
christianchevell
old school chevy rodder
christianchevell's Avatar
inline fuses anywhere in the line that feeds the main power? anyone weld on your car? sounds like a short..........
Old 04-06-2014, 10:09 AM   #7
ChrisBlair
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3
To me this sounds like a classic chassis ground issue.
ChrisBlair is offline   Reply With Quote
Old 04-06-2014, 10:10 AM   #8
jkchambless
Austin LT
jkchambless's Avatar
Drives: 1LT - Airaid,JBA Axleback,VMax PTB
This
jkchambless is offline   Reply With Quote
Old 04-06-2014, 03:00 PM   #9
charles s
charles s's Avatar
well the damage was to the rear fender above the passenger side back wheel. is there any way to know for sure If it is a chassis ground issue? and the mods on my car shouldn't matter, it only started happening after I brought it in for the work.
Old 04-06-2014, 03:08 PM   #10
oldfriend
Drives: Fiat 500 E
It does matter
After all you would have to find what and where the problem is , then you can find out what caused it
Only after those things have been solve you will have a clear picture of the all thing
Old 04-06-2014, 05:37 PM   #11
Outlander
Drives: 2014 Camaro LS
That you aren't experiencing blown fuses, the problem goes away and had recent body work I'd be looking for a ground connection that was painted or not screwed down tightly.
You didn't mention the vicinity of the repair but if it was in the proximity I'd take it back to the dealership that did the work. They should be equipped for the task.
Outlander is offline   Reply With Quote
Old 04-06-2014, 06:05 PM   #12
ChrisBlair
Buick 455 Fan
Where's the 21st century equivalent of a ground strap on these cars?
Old 04-06-2014, 07:39 PM   #13
charles s
charles s's Avatar
there is a picture of the original dent now.
Old 04-07-2014, 07:33 PM   #14
charles s
charles s's Avatar
well made it to gm today see what they say in the next few days.
