![]() Drives: 2010 2SS Join Date: Mar 2013
First day at track yesterday....
So,
Yesterday was the first time I've taken my SS to the track, overall was disappointed with myself, granted I still had car seat, stock tires, and trunk full of shit, I don't think it would have made that much of a diff. But i had a major issue on the first run and going to call the dealership tomorrow. First run: 22.89@83- No traction control, left at 3300rpms, slipped clutch a tad and hammered it, well....clutch pedal stuck to floor to about 1000ft mark then i got it off with my foot. Second run- all traction controls on, babied off the line because of paranoia, 13.4@109 with a SHITTY 60' 2.272, reaction was .732. My 60 killed me. I was so worried about the clutch sticking, I probably shouldn't have made that second run but drop over hour and half to the track. We went for a wedding and I decided hey, why not i'm here. any ideas on the clutch?
2010 RS/SS - C.A.I Intake, Muffler Delete, Skip Shift, VMAX TB
old school chevy rodder
you should have installed a separate clutch reservoir from gen5diy and cleaned the fluid literally every few thousand miles AS IT DOES MATTER. I have seen the darkened fluid I have taken form my separate reservoir and am glad it does not share with the brakes as both are off parts that generate heat and the clutch more contamination ...... that's my thought.
![]() Drives: 2013 SW 2SS/1LE Join Date: Jan 2014
I heard somewhere about a TSB that clutch pedal getting stuck and not depressing. Not sure what model years but I would talk to your dealer about it.
Drives: 2010 2SS/RS Join Date: Jun 2009
No experience, m6, and stock tires a 2.2 isn't as horrible as you make it out to be. It's something you get better at with practice and then mods
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '69 SS Convertible Join Date: May 2009
Yes...get you a clutch reservoir and make sure to change it out with DOT4 before you go to the track every time.
Going easy off the line is about the only way you can do it with street tires.
Build Journal ![]() |
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 aqua blue SS/RS M6 Join Date: Feb 2010
Old dirty fluid really kills the performance of the clutch. Listen to what they said, also look into the LP clutch return spring. Your gonna need all the help you can get, as you can see I run a th400 now. I had all kinds of problems at the track, always seemed fine on the street untill I did a burnout at the track. Seems like its heat related, cooler days I would less problems. I did manage to run 1.9 with 1.87 60ft on street tires with the m6, but always had a 1-2 high rpm shift issue.
10.91 at 122 H/C stock block N/A
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
Anytime the pedal sticks just abort the run.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
#8 |
The clutch sticking is a common issue due to dirty fluid. The best fix is one of our Clutch reservoir separation kits, Lingenfelter Clutch return spring, Tick Clutch line and keeping the fluid clean.
Let me know if you have any questions. Best regards, Tyler 888-308-6007 |
#9 | |
Another thing that helps is to not come off the floor at the line, you want the clutch just shy of moving the car. This way the pressure plate has a less likely chance of sticking in mid swing.
#10 | |
#11 |
There's nothing wrong with the manual tranny and rear gearing. #1 issue is the clutch GM put in these cars.
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: My wife crazy with my C5 usage. Join Date: Apr 2009
OP,
How many miles do you have on the car?
#13 |
thanks for the replies, 61k miles, and I'm looking into all suggestions on this forum, as the dealership said 600 just to look at it, check for abuse, then get back to me on warranty.
#14 |
First thing to do is the clutch reservoir. Start off looking here:
http://www.camaro5.com/forums/showth...light=resivoir Get a kit from JDP or Gen5Diy. Change out the fluid every time you get ready to go to the track and then at your oil change intervals. Use DOT4 fluid. This alone will help out more than you think and it's relatively cheap/easy mod to do. When you change out your clutch add a remote bleeder and the Tick clutch line. The remote bleeder will allow you to flush out more fluid. Also consider adding a line lock if you do any kind of a burn out at the track. That will help keep you from heating up the clutch.
