Old 04-06-2014, 08:08 PM   #1
kc ss/rs
kc ss/rs's Avatar
Drives: 2010 ss/rs
stainless power headers
another happy customer here! this afternoon me and a friend installed them in about four hours with hand tools and floor jacks. i already had a rotofab intake installed and ported throttle body. next up will be a tune. this is an l99 vehicle so the tune should be the icing on the cake. i will be using hp tuners and plan on going with pcm for less for the tune. nice deep mellow sound with the slp axle back that was on the car when i purchased it. its amazing the difference it made without the tune. did not realize how restrictve the factory catalytic converters are. one question i did have did anyone else have a rattle from the rear crossmember after the headers were installed? i did keep the factory resonator.
kc ss/rs is offline   Reply With Quote
Old 04-06-2014, 08:38 PM   #2
2SS2010
Drives: 2010 2 SS
I installed a set of SP catless longtubes on Friday evening with a set of GMPP off road axle back and it sounds friggin awesome. Ive gotten a lot of compliment's on how it sounds.
2SS2010 is offline   Reply With Quote
Old 04-06-2014, 08:41 PM   #3
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Is it hitting the tunnel brace? That's a common thing when you do exhaust mods. There's a trick to keeping the piping up high enough so it won't hit the brace once they relax.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 04-06-2014, 08:45 PM   #4
2SS2010
Drives: 2010 2 SS
I put the jack under my H pipe before I tightened everything, drove it for 2 days and no issues yet
Old 04-06-2014, 08:48 PM   #5
axis
Search Ninja
axis's Avatar
This works or even easier is to put a 2X4 between the pipes and the tunnel brace, then tighten everything up.
Halltech CF 102 fed
Old 04-06-2014, 09:06 PM   #6
kc ss/rs
kc ss/rs's Avatar
Drives: 2010 ss/rs
thanks
Old 04-06-2014, 09:23 PM   #7
umiami2312
Drives: 2013 2SS/1LE Blue Ray Metallic
i have this same setup with the fuse pulled and its ear candy all the time.
Headers really woke up the car after i put them on.
umiami2312 is offline   Reply With Quote
Old 04-07-2014, 07:23 AM   #8
2SS2010
Drives: 2010 2 SS
What fuse do you have pulled?
Old 04-07-2014, 07:52 AM   #9
YUHATIN
Drives: 2013 BLACK 2SS/RS LS3
I LOVE THESE HEADERS AS WELL! THEY SOUND AWESOME, AND GAVE ME SOME GOOD GAINS AFTER TUNE! I ALSO PULLED THE FUSE. ITS IN THE TRUNK BEHIND THE CARPET ON THE RIGHT SIDE. FORGOT THE #, ITS IN THIS FORUM, SOMEWHERE. SORRY
YUHATIN is offline   Reply With Quote
Old 04-07-2014, 08:33 AM   #10
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
+1!!!!!
I have the mild to wild installed, but love the sound so much that 90% of the time the flaps are WIDE open.
I must say at times it has a bit more rasp than I like, but the overall sound is so amazing I dont want to lose that by adding a resonated x-pipe.
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 04-07-2014, 09:08 AM   #11
2SS2010
Drives: 2010 2 SS
You talkin for the NPP exhaust?
Old 04-07-2014, 09:22 AM   #12
black.
Drives: IBM 2SS
If there's rattle in the crossmember I'd suggest adding a couple of washers between the body and crossmember.
black. is offline   Reply With Quote
Old 04-07-2014, 10:31 AM   #13
YUHATIN
YESSIR!
Old 04-11-2014, 07:41 AM   #14
YUHATIN
F8 PULL THAT SHIT! YOULL LOVE IT!
