Old 04-07-2014, 03:55 PM   #1
digdeep0169
digdeep0169's Avatar
Drives: 2012 Camaro SS 45th Anniversary
WTB: what do you got?
I've been "called out" by a local 2012 5.0L m6 - we have an annual "All Out Call Out" and he's picked me. I need to lighten up the car if i want this L99 to get off the line.
Does anyone have a Carbon Fiber hood for sale? things like this... chime in.
I've done all the bolt on adders.
thanks,
Ray
~ 2012 SS ~
digdeep0169 is offline   Reply With Quote
Old 04-07-2014, 04:05 PM   #2
ROD_SS
ROD_SS's Avatar
Drives: 2013 1SS Camaro and a truck
From different threads I seen. The carbon fiber hood wouldn't make that much difference since our hoods are not as heavy as u think.
You can reduce weight by
-lighter wheels
-the driver seat/passenger seat
- don't have that much fuel in your tank
Probably best to get some tires
ADM tuned (465 rwhp / 442 torque) Mods- CAI, kooks long tube headers, & ADM stage 2 cam
ROD_SS is offline   Reply With Quote
Old 04-07-2014, 04:06 PM   #3
tanur420
Drives: 2011 Camaro SS
Lighter wheels and rotors can net you 60+ lbs
tanur420 is offline   Reply With Quote
Old 04-07-2014, 04:06 PM   #4
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Our hoods are aluminum so you wont save much if any by going carbon fiber there. Maybe trunk lid is something to look in to, not sure on weight savings there. Back seat delete also worth a look.
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 04-07-2014, 04:09 PM   #5
ClawSS
High-tech Redneck
ClawSS's Avatar
Drives: '10 CGM SS, '02 2500HD, '09 300SRT8
dangit...wheels...that was what I was gonna say...easiest and cheapest if you can borrow them.
you don't need that pesky exhaust do you?
"My friends call me Chris. Are you my friend?"
2010 CGM L99 2SS/RS - GPI SS3 VVT, BTR DoD Delete, Circle D 4c, BTR springs, Katech C5R Timing Chain, MRR-228 315/275, CAI, Elite catch-can, TSP 1 7/8" Headers + offroad pipes, Magnaflow 3", Pfadt springs, BMR LCAs, toelinks, trailing arms, cradle bushings, & sway bars w/ endlinks, Vitesse paddles, heritage grille, and an eBay splitter. Power upgrades by Race Proven Perf.; Tuning by ShorTuning.
ClawSS is offline   Reply With Quote
Old 04-07-2014, 04:09 PM   #6
Rcfiddy1
Sold car...
Rcfiddy1's Avatar
Drives: 2010 Rally Yellow 2SS/RS #37115
Remove weight
Take out back seat, passenger seat. Trunk crap. Run with half a tank or less. Get a smaller battery, and some drag radials. Are you tuned?
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust.
Rcfiddy1 is offline   Reply With Quote
Old 04-07-2014, 04:10 PM   #7
digdeep0169
without a doubt Rod_SS - these Niche's will not be what I race in. I'm getting WELD RT-S 17". I haven't removed the stock hood, so I'm uncertain as to how much it weighs, but good to know it doesn't weigh a lot. I'll have 1/4" tank or less gas. I'm just trying to think of every possible option to rid of weight, but still daily drive it. Since I'm not putting much power down, i don't see myself going all out "drag" in this. but would be nice to put a "W" up for us Gen5'ers (esp - against the 5.0L)
~ 2012 SS ~
Old 04-07-2014, 04:13 PM   #8
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
Seems like a bolt on L99 should be pretty up there against a 5.0. Any idea on his driving ability? It would be much easier on your part with the auto, he has a high likely hood of messing up the launch or a shift.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 04-07-2014, 04:14 PM   #9
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
HAHAHA...I like your style, good luck man!
Old 04-07-2014, 04:21 PM   #10
digdeep0169
i hope so Destructo09. the guy I'm racing... is a beast. he's the typa guy who bounces off the rev limiter, slides his foot to left of the clutch, drops the hammer! i can only hope he misses a gear. he's done every bolt on possible as well, but hasn't geared. I'm on 3.91 gears, high-flow cats, X pipe. even with my big Niche wheels, she scoots pretty nice! she's seen 130 no problem. @ST1LE - thanks man. anything to give us the "upper hand" in terms of bragging rights. there will be many there, so I'm sure there will be vids to follow. Yes, i'll strap on the "go-pro" facing backwards to see if he can "reel" me in!
~ 2012 SS ~
Old 04-07-2014, 07:25 PM   #11
servax
Drives: 11' Camaro 1SS
Strip what you don't need on the car.
The backseat itself is ~15 lbs and takes no time to remove. The access door is another ~17 lbs, which unhooks from the bracket. Rear battery trunk lid is another ~5 lbs. If you want, you can also swap the battery which weighs in at 46 lbs for a 21 lb from Deka (ETX-30L). Each gallon of fuel is approximately ~6 lbs, I go 1/8th and carry a spare 5 gallon tank of gas. Also make sure you have good tires to hook, that ends up being a pretty big problem when you reduce weight..
First ProCharged i-1 L99 Engine in the World!
ProCharger Stage II Intercooled Tuner Kit with i-1, Injector Dynamics 1300cc Injectors, Squash E85/Gas Duel Fuel Pumps w/ Hobbs Switch, Kooks LT Headers, MagnaFlow Mufflers, Full 3' FlowMaster American Thunder Exhaust, K&W Variant 3, Jannetty Racing Tuned
servax is offline   Reply With Quote
Old 04-07-2014, 07:45 PM   #12
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
What do you have rear gears? I would say look at changing them out so have a quicker launch.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs
rberns is offline   Reply With Quote
Old 04-08-2014, 11:08 AM   #13
digdeep0169
@servax - yup - these are all great suggestions and easy to remove come race day. i plan to go with 1/8 tank gas. they have race fuel there onsite should I need a gallon or so. @rberns - I'm running 3.91 gears and this car scoots off the line very nice. we also changed the rear differential bushings to solid bushings, on order is lower control arms to clear the 17-10 Welds - rear tire will be 325/45 - 17"
~ 2012 SS ~
Old 04-08-2014, 01:02 PM   #14
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
Yeah the stock hood is only 25LB if I remember right.
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
