Old 04-07-2014, 03:59 PM   #1
braggs2ltrs
braggs2ltrs's Avatar
Drives: 2011 Black 2LT RS
4.5 qts of oil low with no leaks
I have a 2011 2LT RS (V6) that was 4.5 qts of oil low and no apparent leaks that the dealership could find. Took it to the dealership for noise from engine. They said it was low on oil. They filled it up (4.5 qts) and sent me on my way. When checking the dipstick, it appeared to be a qt low they said and I agree because that's what I saw. They kept filling it up. Where did it all go? A week later I am back at the shop with god awful engine noise. 62k miles and the dealership wants to drop the oil pan to look for metal and sludge. They say its an 11 hour job. Is it really 11 hours to drop the oil pan?
braggs2ltrs is offline   Reply With Quote
Old 04-07-2014, 04:06 PM   #2
Spektrum
Spektrum's Avatar
Drives: 2013 2SS 1LE
Can't answer about your oil consumption problem without speculating, but the labor hours for R&R the oil pan is 10.8 hours, so they're correct.
Spektrum is offline   Reply With Quote
Old 04-07-2014, 04:17 PM   #3
RobertRS
RobertRS's Avatar
Drives: 2014 2SS L99
Dealer should have drained all of the oil in the first place before just topping up 4.5 quarts. At least then you could have known how much came out. Something seems off on your dipstick readings.
RobertRS is offline   Reply With Quote
Old 04-07-2014, 04:31 PM   #4
braggs2ltrs
Yep. Must have been unlevel ground that we both checked the oil on! That's at least what was said to me!
Old 04-07-2014, 09:09 PM   #5
Avenging Orange
Avenging Orange's Avatar
Sadly, those engines have an oil eating issue. Just suprised it reared its ugly head this late. Let the dealer do their thing. Prob end up with a rebuilt engine.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 04-08-2014, 08:55 AM   #6
TooCool5
TooCool5's Avatar
Yes we have seen this before on the forum.
Old 04-08-2014, 09:22 AM   #7
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Yep, this is very common with the LLT engines!
FSP tuned: 377/389
Old 04-09-2014, 04:27 PM   #8
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
My car uses 1qt. every 1500 miles. It's been said time and time again, these engines use oil. Check Your Oil at least once a month. I have a catch can that catches a few onces a week, it's not all oil, it's oil and water mixed. there is a thread on here, that tells a story of a guy running out of oil and replaced the engine. Remember, Oil Pressure is not Oil Level.
Eddiefuzz is offline   Reply With Quote
Old 04-09-2014, 07:09 PM   #9
TooCool5
TooCool5's Avatar
Mine uses very little between changes and I never have to add, so all LLT engines
were not built the same, nor in the same location.
Old 04-09-2014, 07:25 PM   #10
nyrfan
Let's go Rangers!
nyrfan's Avatar
I honestly don't think that's it, I think it has to do with how the car was broken in. I broke mine in hard right off the lot (when I had my 2011 LLT) and I never lost any oil and my engine was strong.
FSP tuned: 377/389
