Old 04-08-2014, 05:42 PM   #1
tylerio
EXTREMZ
tylerio's Avatar
Drives: 2015 Z/28 #891, 2012 2SS 45th Anni
Help with spacers
I have 20"X10" Forgeline wheels with Michelin PSS 295x35 ZR20 on all 4 wheels of my 2012 Camaro SS. Turns out, the front tires are rubbing slightly against the struts. Rears are fine. Someone suggested spacers would solve the problem, but I don't know anything about spacers or where to order them. Would that be a good solution? Thank you.
tylerio is offline   Reply With Quote
Old 04-08-2014, 06:37 PM   #2
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
I just ran into this and any spacers will do i'd get the eibach ones higher quality you can find them from their homepage or through any vendor like summit etc. It's gonna run you another $140 roughly with shipping.
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile
Evil-Bee-NH is offline   Reply With Quote
Old 04-08-2014, 07:01 PM   #3
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
THIS is where you want to get your spacers from ...custom cut from billet aluminum.
http://www.motorsport-tech.com/wheel_spacers.html
First determine how many mm of clearance you'll need then, then subtract that from the stud length to make sure you have at least 21mm of stud left to fully tighten lug 6/7 turns ( our std length is 28mm, our stud size is 14mm x 1.50, industry std calc for required lug tightning length for 14mm x1.5 = 21mm. I was able to get around 9 turns of the lug with a 3mm spacer I used, 100% of the torque is achieved at the 6 turn, the extra turns don't add anymore tighting/torquing)
If you don't have a least 21mm of stud length with a spacer you'll either have to add longer studs or go with an adaptor instead of spacers.
camguynj is offline   Reply With Quote
Old 04-08-2014, 07:17 PM   #4
Retro69
Retro69's Avatar
Drives: 2018 Camaro ZL1
I'm looking at the exact same size wheels/tires and have been wondering about how they would fit. Are you lowered or stock height? Do you know what your wheel offset is? Same offset front and rear or different?
Sent from my iPad using Tapatalk HD
Retro69 is offline   Reply With Quote
Old 04-10-2014, 08:55 PM   #5
67motorcat
Blown Cool Breeze
67motorcat's Avatar
Drives: 2011 Black on Black 2SS M6
I hate to say this OP....
But knowing how much dough you put out for your Forgelines....alot....
I would send them back to have the offset corrected so they fit properly.
Who ever you bought them from gave the wrong offsets for the order.That size front should fit perfectly and has been done before.
Depending on what style Forgeline you have ,it may be necessary to run different offsets front and rear even though a common width is shared.
Of course that would mean no rotation capabilities...no biggy for most
Defiantly would not run spacers on the front
Had a 2010 IBM 2SS M6
Enjoy life.Think of all the women on the Titanic who passed up dessert.
67motorcat is offline   Reply With Quote
