Old 04-08-2014, 08:56 PM   #1
camaropop
Drives: 2010 Camaro ss eforce
Broken belt tensioner again E Force supercharger
Just broke the 2nd belt tensioner that comes with the eldelbrock e force kit. Both times has been since I put the nitto drag radials on and they broke after a hard launch. Summit warranted it since it was purchased on 12-17-13 but I need a solution. I called eldelbrock and they didn't have any recommendations and claim they have not heard of this issue. Does anybody have any experience with the special made for eldebrock Dayco belt tensioner?
camaropop is offline   Reply With Quote
Old 04-09-2014, 08:27 AM   #2
camaropop
Pictures of tensioner
Old 04-09-2014, 09:11 AM   #3
cal45
cal45's Avatar
Drives: 2015 Blue Velvet Metallic ZL1
What boost are you running this at?
cal45 is offline   Reply With Quote
Old 04-09-2014, 12:23 PM   #4
sscamaro
Drives: 2010 2SS, 2017 Silverado LTZ
Are you using the Goodyear Gaterback #4061045 6PK2655 belt that came with the kit? I've had the original belt on mine for 3.5 years and 26K miles and haven't had a problem.
sscamaro is offline   Reply With Quote
Old 04-09-2014, 07:51 PM   #5
camaropop
It makes about 9-10lb
Not exactly sure on the part # on the belt bc the car is at my mothers till the tensioner comes in bc that is where I was when it broke. but I assure u its the proper belt that's ca whole nother story alone and the hash marks were lined up properly
Old 04-09-2014, 08:20 PM   #6
lbheat
Echale Gas [COTW 3/10/14]
lbheat's Avatar
Drives: 2010 Camaro SS/RS Supercharged
Wow that thing completely sheared off!!?? Are all the pulleys correctly lined up? Any type of belt hop?
Kenne Bell
502 rwhp/ 471 rwtq at 9psi (daily driver...for now)
Performance: Corsa catback, JRE Super Tensioner, dual pass heat exchanger, R1 slotted & Dimpled rotors cryogenically treated
Cosmetic: Giovanna kilis 22", zl1 mailslot bumper, Custom Emblem Pro Badge, painted calipers
lbheat is offline   Reply With Quote
Old 04-09-2014, 10:22 PM   #7
camaropop
Does anybody know of any billet spring loaded tensioners eldebrock doesn't recommend using a fixed tension and I agree after seeing how much belt stretch and back lash it can produce.
What are stronger options?
Old 04-10-2014, 02:32 PM   #8
Ret Fuzz
Banned
Drives: 2010 Camaro
http://www.summitracing.com/parts/ed...FUpnOgodEQgAbQ
http://www.phastekperformance.com/20...-tensioner.htm
http://www.speedinc.com/katech-adjus...tensioner.html
Im looking for ya...
Ret Fuzz is offline   Reply With Quote
Old 04-11-2014, 03:13 PM   #9
camaropop
Still looking for help.
Old 04-11-2014, 07:23 PM   #10
Ret Fuzz
Banned
Drives: 2010 Camaro
did you look into any of those?
Old 04-12-2014, 04:06 AM   #11
camaropop
The brace doesn't fit mine and I can't find anyone that can make a brace to help it and eldebrock doesn't recommend a fixed tensioner
Old 04-12-2014, 01:05 PM   #12
forklord
forklord's Avatar
Drives: 2010 2SS
that looks like the old style tensiober to me. edlvrock sent me the new one for free. i had to add washers and a bolt for srength and to line up the tensioner properly tho but it does look a little bit sturdier. well the tensioner anyway. the bracket is thinner to make up for the beefier tensioner. edwlbrock was lying if they said they havent heard of it
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
Old 04-12-2014, 02:54 PM   #13
Busy_Boi
SoCal C5 Family Member
Busy_Boi's Avatar
Drives: RJT 2010 camaro 2SS
Send a message via Yahoo to Busy_Boi
Look on this website for edelbrock there is a upgraded tensioner on there website I bought one two week ago. The one you have looks like the old one hope this helps you.
http://www.edelbrock.com/automotive/...mponents.shtml
Busy_Boi is offline   Reply With Quote
Old 04-12-2014, 06:20 PM   #14
SSBUSDRVR
SSBUSDRVR's Avatar
Drives: '11 2SS/RS IBM/BLK M6
Sorry to see/hear. Never had a problem here with the tensioner. Now the rest of the engine is another story. Hopefully SC is OK. It was shipped to Edelbrock for a lookover. Hope you get it fixed.
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416
ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly
SSBUSDRVR is offline   Reply With Quote
