Old 04-08-2014, 11:40 PM   #1
lionssfan
lionssfan's Avatar
Drives: 2010 2ss camaro
want to fabricate a stainless works exhuast system to dual mode
Yea guys, Looking for some input, anybody know if its possible to make a retro chambered stainless works exharst system into a dual mode by fabricating? Possibly purchase a gm dual mode butter flies and npp controll box from gm warehouse. Any other ideas appreciated. Love the retro chamber sound just would like to tone it down when needed. thanks
lionssfan is offline   Reply With Quote
Old 04-09-2014, 07:47 AM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Is it possible? Sure. You couldn't just put the valves directly on the Retro Chambered though. You would have to get the Retro Chambered cat back and a set of NPP dual mode mufflers and install them on the rear of the cat back to get it to work.
Old 04-09-2014, 08:31 AM   #3
SomeGeoffGuy
SomeGeoffGuy's Avatar
Drives: 2023 2SS Convertible
I didn't think they sold just the valve. If you find a way to get it, let us all know!
-Geoff
'12 2SS RS Convertible - Traded in.
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold!
'23 2SS Convertible -Same as above except orange.
SomeGeoffGuy is offline   Reply With Quote
Old 04-09-2014, 08:45 AM   #4
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
This will cost you well over $2000 for parts alone!! I like where your head is at though.
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 04-09-2014, 08:59 AM   #5
lionssfan
lionssfan's Avatar
so run the retro chambered pipes thru the npp dual mode mufflers? Your saying cutting open the npp dual mode mufflers if I understand and fabricating the retro chambered pipes to run inside the muffler right? I did call SW if they had any future plans for a dual mode setup and they said no at this time...darn it.
Old 04-09-2014, 09:03 AM   #6
lionssfan
lionssfan's Avatar
yea not cheap. I do metal fabricating for a living so that will help some on the cost.
Old 04-09-2014, 09:07 AM   #7
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Thats awesome! I am excited to see what the end result is. One word of advise(you prob know) is look on the classifieds. Seems there is always a NPP for sale in the ZL1 section and I have seen a couple retros too, but thats NOT common.
Old 04-09-2014, 09:13 AM   #8
Apex Motorsports
The chambered sections of the Retro Chambered are up under the car where you would normally expect resonators to be. I would just hack of the back of the SW system and attach the NPP mufflers like an axle back.
Old 04-09-2014, 09:36 AM   #9
lionssfan
lionssfan's Avatar
Gotcha you now Apex. So you think the "sound" of the SW retro chamber exhaust sys should sound the same even though it's going thru the npp mufflers? If you know thanks Apex
Old 04-09-2014, 09:51 AM   #10
Apex Motorsports
When the valves are open the NPP is straight through so under those conditions it would be the same. When they were closed it should be more subdued but still have the deep tone and growl.
Old 04-09-2014, 12:47 PM   #11
Three of Swords
Three of Swords's Avatar
Drives: 2011 IBM 1SS/RS L99
Just a reminder: There are two sets of chambers on each pipe. One it located in the 'resonator spot' (as Chase says), but another is in the 'muffler spot'. If you install as Chase says, you'll lose one of those chambers.
I'm not sure how much it will change your sound by eliminating one. You might be able to add it upstream though.
Note: I just installed a retro-chambered catback yesterday. It sounds awesome. I understand the desire to keep the sound!
Three of Swords is offline   Reply With Quote
