![]() ![]() Drives: 2015 2SS/RS Summit White Join Date: Nov 2008
SS in Snow
Anyone drive their SS auto in the winter/snow. Was it doable?
Too much is never enough!
I took my SS out of storage one day and got caught in the snow and ice. TBH it was like a skateboard on ice. I choose to get a winter vehicle.
![]() ![]() ![]() ![]() Drives: 2011 IOM 2SS/RS M6 Convertible Join Date: Feb 2014
with the right tires, Camaro's aren't bad in up to a couple inches of snow... much more than that and they turn into snow plows.
Wouldn't even take it out of the garage on the stock Pzero's though... they call them Max Summer tires for a reason.
I usually store mine around November and around that time when its about 30 degrees or so the PZero does not stick to the ground very well.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs |
mmmm..... displacement :)
Drives: 2010 Black n' Yellow LS3 Join Date: Apr 2013
drove mine for a day in the snow when my truck was broken down and with the manual it was not the best. i put 500-1000km on a day for work driving in all types of weather and by the end of the day driving my car i basiacally had decided it was not a great idea.
That being said, with good tires and a steady foot anything is possible ![]() i would just suggest winter tires. Where i live theres 5-6 Gen5's that i know of that drive year around and we get some pretty heavy winters |
#6 |
I'm just trying to figure out how to make this work. I have a '97 Z28 that I store in winters but I'd like to get a gen 5 and get back down to 2 vehicles. Mine and my wifes.
I did drive my Z28 in the winter for about 8 years so I wonder how much worse than that it could be. |
#7 |
The car does fine in the snow. Pay very little attention to the posts you see here about it being worthless in the snow and try it for yourself.
As with all driving, the conditions dictate how and if you should drive. It is not AWD. Like any vehicle, the icier the conditions the more dangerous it is to drive but a seasoned driver with RWD experience should not encounter significant difficulty driving a C5 in snow. Everyone's situation is unique. If you're a firefighter or emergency personnel of some sort that is required to report to duty no matter the conditions, the Camaro probably should not be your go to vehicle. If you are afforded the luxury of deciding if and when you drive in hazardous whether, it very well could fit your needs. |
#8 |
![]() Drives: 2013 Camaro 2SS 6 Sp Dusk Edition Join Date: Sep 2013
Threads like these remind me why I love living in San Diego
2013 Camaro 2SS Dusk Edition 6 Speed
#9 |
Turbine Maker
Drives: 2012 Camaro 2LT-RS "LFX"V6 Join Date: May 2012
Not with stock tires.
#10 |
![]() Drives: 2016 Camaro 2SS Join Date: Oct 2013
I did the stock tires through winter in Chicago, useless with snow, beyond that they worked just fine.
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Evil Eva, 2010 2SS LS3 Join Date: Aug 2013
I have 409 RWHP on a mustang dyno, and stock tires.
I had to drive in the snow twice this winter. It was not easy, but it was doable, but just barely. It was worse when the car and tires had not warmed up at all.
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
#12 |
Lifestyle = Deathstyle
At least 6 months away! Wooooooo! Definitely should have a winter tire setup if you must drive in the snow.
#13 |
![]() ![]() ![]() Drives: 2013 Camaro 2SS/RS BRM LS3 Join Date: Jan 2013
I drove mine all winter on the P-zeros. Not one problem here.
#14 |
SSmokinJoe
Drives: 2010 SIM 1SS/RS M6 Join Date: Feb 2010
Mine is a daily driver, so I've driven it through 4 winters in Pennsylvania. As stated, get winter tires (or all-seasons), and it does fine. Sometimes I need to turn off traction control and start in 2nd gear, but I only got stuck once in 4 years.
1SS/RS Silver with Black Rally Stripes.
35% Tint Roto-Fab CAI SLP Loudmouth II Axleback Hurst Shifter R1Concepts Slotted Rotors Hawk Ceramic Brakepads I drive way too fast to worry about my cholesterol. |
