Old 04-09-2014, 11:30 PM   #1
Blown355
Blown355's Avatar
Drives: 2017 ZL1 A10
Installed Kooks headers today
Kooks headers arrived today, so figured I'd spend a couple of hours getting the project started. Next thing I know I'm almost finished! By far the easiest header install I've ever done. Started a 7 pm and called it a night at 10:05. The only things left to do is re-install the spark plugs, wires and O2 sensors. Oh, and the dipstick.
2017 ZL1
A10
Redhot with stripe
Blown355 is offline   Reply With Quote
Old 04-09-2014, 11:38 PM   #2
EvilZL1
Snake Eater
EvilZL1's Avatar
Drives: 2012 AGM ZL1
Sweet looking forward to a video
Build Thread: http://www.camaro5.com/forums/showth...95#post8351295
Make sure you don’t forget to subscribe to my channel! More content on the way. Like, share with your friends
https://www.youtube.com/channel/UC9Z...sP2wjsLLFeP1zQ
Follow me on instagram:
http://www.instagram.com/snkeatr/
EvilZL1 is offline   Reply With Quote
Old 04-10-2014, 09:55 AM   #3
wirebender
wirebender's Avatar
Drives: 2017 ZL1, A10, White, sunroof, nav
2"? Looks good!
wirebender is offline   Reply With Quote
Old 04-10-2014, 02:43 PM   #4
Lethal Z
American Gearhead!!
Lethal Z's Avatar
Drives: ZL1 1LE/GT350/Ford RS/Gen 2 Raptor
Lets see how you cut the underbelly tray? I'm doing the same install next week....
Lethal Z is offline   Reply With Quote
Old 04-10-2014, 03:30 PM   #5
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
Nice!
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 04-10-2014, 04:55 PM   #6
jeffrop
jeffrop's Avatar
Drives: 2020 ZL-1 M6
I've got a set of these in my living room waiting to be installed. Finally got the car out of storage just need to find some time to do the install. I'd be interested in any further tips/comments from your install!
While I'm thinking about it, did you re-use your stock gaskets or the Kooks fiber ones? Or did you go new stock?
Thanks!
jeffrop is offline   Reply With Quote
Old 04-10-2014, 05:32 PM   #7
Blown355
Blown355's Avatar
Originally Posted by wirebender View Post
2"? Looks good!
1 7/8.
2017 ZL1
A10
Redhot with stripe
Old 04-10-2014, 05:50 PM   #8
2011shelby
Drives: 2011ShelbyGT500
Do you have a before and after dyno to compare gains??
I had a decent gain when I added long tubes.
2011shelby is offline   Reply With Quote
Old 04-10-2014, 05:55 PM   #9
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Nice!
Thanks!
Either reuse the stock gaskets or get some new OEM manifold gaskets. We recommend new OEM gaskets. Cheap insurance against leaks.
Best regards,
Tyler
888-308-6007
Old 04-10-2014, 08:36 PM   #10
Blown355
Blown355's Avatar
Tips:
Remove the strut tower brace. Makes it easier to get to everything.
Hit the exhaust bolts (holding the cat pipe to the exhaust manifold) and O2 sensors with WD40 the night before.
Get the car well off the ground. Makes it easier to slide the headers in from the bottom.
Don't use the cheap gaskets that came with them. Use the GM ones. PN: 12617944
It's actually pretty easy.
Tools:
10 mm socket
13 mm socket
15 mm socket
O2 sensor tool
Spark plug socket
Anti-seize
Thanks!
2017 ZL1
A10
Redhot with stripe
Old 04-10-2014, 08:40 PM   #11
Blown355
Blown355's Avatar
Probably not going to dyno it again before I put the 9.55 crank pulley and FIC850's on.
2017 ZL1
A10
Redhot with stripe
Old 04-10-2014, 08:47 PM   #12
Blown355
Blown355's Avatar
Here's another tidbit of information.
Stock manifolds =10.5 lb each
Cat pipes =12 lb each
Kooks headers = 12 lb each
Cats = 3 lb each
Weight savings= 15 lbs
2017 ZL1
A10
Redhot with stripe
Old 04-10-2014, 09:32 PM   #13
ricky_ZL1
Drives: 2013 ZL1 Camaro
I just installed mine too. Great run thru.
ricky_ZL1 is offline   Reply With Quote
Old 04-11-2014, 12:17 PM   #14
Nickmo
Nickmo's Avatar
Drives: 2012 ZL1 CTF#69
Great tips! Thanks for posting!
Are you running a CAI? Thrown any codes since install?
Nickmo is offline   Reply With Quote
