Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 3rd Generation Camaros
Old 04-10-2014, 04:59 PM   #1
BLACK2SSRS
Drives: Black 2SS/RS
Fuel pump wiring
I thought that I needed a new fuel pump as I did not hear it engage when the ignition was turned over. When I went to disconnect the black protected line from the fuel pump to its connection behind the rear seat I found that they were not attached.
I reconnected the two and the car runs, pump is fine. This is where the problem lies. The piece that is mounted to the car has a clip that holds the fuel pumps connector into place; this is broken, thus the two do not stay together.
I removed the carpet from the interior rear seat and found where the connection is. However it appears to be rivet welded into place. Couple of questions.
What is the part called that I am specifically looking to replace? Is it an entire wiring assembly or is it simply an all weather connection that needs to be swapped? Do I have to pop the rivet welds to replace broken connector?
1992 RS 3.1 4speed auto.
Any help is appreciated.
BLACK2SSRS is offline   Reply With Quote
Old 04-15-2014, 01:10 AM   #2
Obsessive Camaro Disorder
Obsessive Camaro Disorder's Avatar
Drives: 69 Camaro and 92 RS
Have any pics?
There are 3 ways to do any project. Good, fast, and cheap. You can only choose two.
If it's done good and fast, it isn't going to be cheap.
If it's done good and cheap, it isn't going to be done fast.
If it's done cheap and fast, it isn't going to be good.
Obsessive Camaro Disorder is offline   Reply With Quote
Old 04-16-2014, 04:10 PM   #3
BLACK2SSRS
I took some, trying to figure out how to post them. Tried uploading but it times out.
Old 04-16-2014, 04:29 PM   #4
BLACK2SSRS
Here is the connection behind the seat.
Old 04-16-2014, 04:32 PM   #5
BLACK2SSRS
This is the connection from the outside behind the seat.
This is where the fuel pump wiring connects.
Old 04-16-2014, 04:42 PM   #6
BLACK2SSRS
As you can see, the clip that holds the fuel wiring is broken. Thus the two won't stay connected.
Old 04-19-2014, 05:02 PM   #7
My first thought is to use a zip tie to hold the connection together.
If the clip on the harness is broke then you probably need to locate and new one. I would call http://www.hawksthirdgenparts.com/ca...6-Accessories/ and see if they have one. If you talk to Bruce Hawkins himself you may get better info than i can offer. Also try www.thirdgenranch.com. Call them on the phone if you don't see what you need on there website.
I also wonder if a Racetronix hotwire kit would cure your problem too. http://www.racetronix.biz/index.asp?...FromFeatured=1
Old 04-19-2014, 08:26 PM   #8
BLACK2SSRS
The zip tie came to my mind also, but the connector is flush with sheet metal, no way to get behind it. I'll look into these links you've given me though. Thanks
Old 04-19-2014, 09:26 PM   #9
Maybe try thirgdgen.org. You can't be the first person this has ever happened to.
