Old 04-11-2014, 12:19 PM   #1
Lnch Mny
Lnch Mny's Avatar
Drives: IBM Camaro
New Torque Converter... No Tune?
I just had a new torque Converter installed. 3200 Stall. I am coming to the realization that all the local tuning experts are backed up. Will running the car with no tune be a serious issue?
Lnch Mny is offline   Reply With Quote
Old 04-11-2014, 12:34 PM   #2
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
I think a lot of stuff will be off - did you drive it already?
If you got HP Tuners you could get a remote tune from someone like GPI.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 04-11-2014, 05:39 PM   #3
Lnch Mny
Lnch Mny's Avatar
Drives: IBM Camaro
John, I babied it home from instalation and it seemed to be fine. I noticed that at one red light I got on it some, but it didn't seem to shift. I called Speed Inc, but they are booked till May and want to redo the entire Tune. I'm hoping Mike Norris can squeeze me in before Camaro Fest.
Old 04-26-2014, 11:31 PM   #4
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
If you get HP tuners or sct you could buy an email tune for it.
I remember seeing a shop on this forum that offers transmission tunes for 75 dollars.
driving it with a stall and no tune can damage the transmission.
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 04-27-2014, 07:50 AM   #5
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Yes, you need a tune. Without a proper tune you will most likely hit the rev limiter on 1st-2nd gear wide open shifts.
Also, tuner needs to look at the lock up.
I made the mistake years ago and put a higher stall converter in my 4th gen Fbody without a tune (because everyone said I'd be okay).
A few weeks later my tranmission was fried and I had to get it re-built.
So get a good tune.
My tuner has actually spent hours (making fine tuning adjustments -part and full throttle tuning) getting my car to run just right with my 3200 stall.
Old 04-27-2014, 08:08 AM   #6
BlackoutLFX
BlackoutLFX's Avatar
Drives: 2012, Black 2LS
I'd go ahead and get the whole transmission tuned asap, and add a transmission cooler if you didn't already.
Nytrex 100 hp nitrous triple threat system, NytrexAccu-pressure bottle heater, HP tuners, K&N Typhoon CAI, MACE 6mm MI, Solo Performance high flow cats, Flowmaster American Thunder cat back exhaust system, BMR subframe connectors, BMR tunnel brace, BMR lowering springs, BMR Xtreme Anti-roll bar rear, Hotchkins Strut brace, SS/LS3 3.45 LSD, Axles, and hubs, Elite Engineering catch can, B&M Supercooler transmission cooler, FTI 3200 Stall.
BlackoutLFX is offline   Reply With Quote
converter, torque, tune
