Old 04-11-2014, 01:09 PM   #1
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
generic(cheap) catch cans...
..do work. Installed mine ^6500 miles(now @ 7200), and have removed about 2 tablespoons of residual oil. Better than not having one. Bolted mine to the front left engine cover pole(don't use cover anyways).
Old 04-11-2014, 02:43 PM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
An empty soda can with two fittings will catch some oil vapor but without any filtration or baffling far more passes straight through than gets caught. Yes, it is better than nothing but not by a lot.
Old 04-11-2014, 02:51 PM   #3
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
Better than nothing, yes. But there's a reason the catch cans we use on the Camaros are made for Corvettes lol
DSX_Camaro is offline   Reply With Quote
Old 04-25-2014, 04:31 PM   #4
BigRed585Lbs
Drives: Sierra and Tahoe
Who you callin' Cheap-*ss, Mistah!
Bling don't mean a thing!
BigRed585Lbs is offline   Reply With Quote
