Old 08-01-2009, 05:36 PM   #1
Rogue Leader
Iatefiberglassinsulation
Rogue Leader's Avatar
Drives: 2010 Camaro 2SS M6
Should have listened to the advice regarding (THE SIX) spoiler bolts (PIX INCLUDED)
cause at 2000 miles one of the nuts backed completely off on my spoiler and is now stuck in the innerworkings of the trunklid
The rattle is quite annoying and I have no way to get it out. I went and tightened the rest now (as all were loose in one shape or form....)
Yet another thing they have to do when I bring it back in a month for the scuff pads to be replaced (they had to install a new rocker cause of the bulge behind the door and the paint hasn't cured yet).
CHECK YOUR SPOILER BOLTS!!!
EDITED TO ADD PICTURE OF BOLT LOCATIONS.
2010 Chevrolet Camaro SS - was daily driver, now toy
2020 Alfa Romeo Giulia Quadrifoglio - Daily Driver
2017 Mercedes Benz GLE 350 - Wifes Car
2008 Chevy Silverado 2500 HD LT 6.0 - Tow Vehicle
1991 Alfa Romeo 164S - Project Car
1994 Volkswagen Golf - Race Car
"Like" my race team on Facebook: http://www.facebook.com/farfrumwinnin
Rogue Leader is offline   Reply With Quote
Old 08-01-2009, 05:37 PM   #2
jpsuperman81
Yep I'm back!
jpsuperman81's Avatar
Drives: 2017 Krypton Green 1SS 1LE
Magnet?
jpsuperman81 is offline   Reply With Quote
Old 08-01-2009, 05:42 PM   #3
Rogue Leader
Originally Posted by jpsuperman81 View Post
Magnet?
I may have a telescoping magnet at my dads house gonna check in a bit...
Old 08-01-2009, 05:44 PM   #4
fbodfather
fbodfather's Avatar
Very sorry to hear about the bolts coming loose.
We did track it down to a faulty torque setting on a wrench on the line......don't have a VIN cut-off but will try to find out.....solved several weeks ago....
Old 08-01-2009, 05:54 PM   #5
Rookie13
Hooked on AutoX
Drives: 1SS/RS
Send a message via Yahoo to Rookie13
Rogue, actually if you follow these instructions, you might have a good chance of removing that nut.
Find a rather large magnet that will penetrate two layers of steel. Put Scotch-tape on the side of the magnet you plan to use, as a protectant.
Find the loctation of the nut by tapping on the deck-lid with your knuckles. Locate the exit hole you need to use and come up with an exit strategy...
Use the scotch-tape coated side of the magnet on the underside of your trunk lid to maneauver the nut thru the channel of the deck-lid or where-ever it is. The magnet should easily move the nut along the inside of the panel so you can get it to the hole and remove it.
Worse case scenario, if you have to use the magnet on the outside of the car (paint) pull off a long strip of the scoth tape, curl the ends and TAB each end; pre-paste the tape by laying it on your pants/jeans, so it is super-sticky. Put the scotch-tape directly on your paint where your exit strategy meets up with the hole. Drag the magnet very carefully across the scotch-tape to maneuver the nut thru the inside of the lid. Have a secondary magnet on standby to help remove the nut from the hole.
Hope this helps. Good Luck!!
Rookie13 is offline   Reply With Quote
Old 08-01-2009, 06:54 PM   #6
djsnoflake
Faith Keeper
djsnoflake's Avatar
Or also wrapping a really strong magnet inside of your shammy/microfibre cloth works good too for the keeping paint safe situation.
Old 08-01-2009, 06:59 PM   #7
domano 68
domano 68's Avatar
Drives: 2014 1LE
I had dealer installed LPO striped installed so no need to worry here.
domano 68 is offline   Reply With Quote
Old 08-01-2009, 07:44 PM   #8
"prima"Donna
HWAY STR
"prima"Donna's Avatar
Thanks for the info, Scott...my VIN is 7085, and "so far, so good"............will definitely have hubby check that for me...............
~ HWAY STR ~
Old 08-01-2009, 08:00 PM   #9
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
I too read the warning on the spoiler bolts and dismissed it. about a week ago I was washing my car and noticed it loose on the driver side. I popped the rubber covers off and tightened them. the one on the inside fell out into the trunk. Guess I got lucky on that one. The rubber covers go back on easily, just push in the middle till it pops. They come off with just your fingers.
Old 08-01-2009, 08:03 PM   #10
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Lots of ways to fish out the bolts in here...
http://www.camaro5.com/forums/showthread.php?t=29678
Old 08-01-2009, 09:44 PM   #11
Daddyo01545
New England C5 Member
Daddyo01545's Avatar
Drives: 2010 Camaro 2SS/RS
Rare earth magnets...even small ones are VERY strong. I agree that you use a polishing cloth and a magnet and you are good to go. I use high heat rare earth magnets on my oil filter and pan to pull out those microscopic metal shavings from the new motor.
Daddyo01545 is offline   Reply With Quote
Old 08-01-2009, 10:09 PM   #12
oachalon
Drives: 2010 Camaro 1SS
i just checked mine and they seem to be tight so all is well for now.
oachalon is offline   Reply With Quote
Old 08-01-2009, 10:13 PM   #13
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
Just tightened mine up. Al four were loose. Tightened about a half to full turn on each.
Rogue Leader, I hope you get that nut out of the trunk lid soon. It would drive me absolutely ape shit.
edog is offline   Reply With Quote
Old 08-01-2009, 10:45 PM   #14
HeatherR
HeatherR's Avatar
Drives: 2009 CTS, 2008 Solstice GXP
Check yours...Stripes were a thought at the beginning, but that was not the cause.
HeatherR is offline   Reply With Quote
SLP 2010 Camaro ZL575 supercharged -- unique aero parts & "SS" on grill nUcLeArEnVoY Camaro Photos | Spyshots | Video | Media Gallery 129 04-22-2010 03:59 PM
Dodge Challenger gets a huge price cut. StoutFiles General Automotive + Other Cars Discussion 207 01-26-2009 08:50 PM
2008 Valero Camaro Sweepstakes (Pix included!) TAG UR IT 5th Gen Camaro SS LS LT General Discussions 44 01-06-2009 07:41 AM
