Old 04-11-2014, 05:53 PM   #1
5th Gen NE
5th Gen NE's Avatar
Drives: Summit White 2011 Camaro SS/RS
Will these tires fit without rubbing?
I currently have a 1.25" drop all the way around and I'm looking at a tire set that will fit and look good without rubbing.
WHEELS: 22x9 in the front and 22x10 in the back.
Would 265/35/22 and 295/35/22 tires work without rubbing?
I'm also looking at
265/30/22 and 295/30/22
and
265/35/22 and 295/30/22
What should i go with?
5th Gen NE is offline   Reply With Quote
Old 04-11-2014, 06:02 PM   #2
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
You need to look at the offset that what will tell you if they rub or not. You need all the info when picking because those sizes will and will not fit depending on design and brand. So what's the offset and what company is it?
Trob85 is offline   Reply With Quote
Old 04-11-2014, 06:37 PM   #3
5th Gen NE
5th Gen NE's Avatar
They are TSW INTERLAGOS and have an offset of 20 on the front and 35 on the back
Old 04-11-2014, 08:33 PM   #4
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '26 Corvette Stingray
THE BACKS will be fine.....not sure about the fronts, but I would bet money they will rub. you really need something between a +32 and a +35 for the front as well.
although mine are 20's, I am running a +40 on the front, but with the taller wheel and tire, I would go at least a +35
22", camaro ss, tires, wheels and tires
