Old 04-12-2014, 11:03 PM   #1
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
ZL1 cam swap
Bored today. Decided to start my cam swap before I have the parts in hand yet. Figured I'd disassemble this weekend and put it back together next weekend.
Strut brace off. Intake off. Throttle body off.
Inside SC snout. Notice no oil in intake and 13 k miles, no catch can on my car.
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 04-12-2014, 11:08 PM   #2
ZO6 Bryan
ZO6 Bryan's Avatar
Radiator out. Rotofab out, necessary to get out the radiator. Pulleys and water pump off. Time to remove damper.
Bryan 2018 ZL1 M6
Old 04-12-2014, 11:10 PM   #3
ZO6 Bryan
ZO6 Bryan's Avatar
Damper off. time to remove front cover. Don't forget 2 bolts on the underside that hold the cover.
Bryan 2018 ZL1 M6
Old 04-12-2014, 11:12 PM   #4
ZO6 Bryan
ZO6 Bryan's Avatar
Timing cover off. Stopping here tonight. Work on the valve covers and rockers tomorrow.
Bryan 2018 ZL1 M6
Old 04-12-2014, 11:18 PM   #5
BPG
Faster than you...
BPG's Avatar
Drives: 1194whp. 8.62@168. daily driver...
Which cam are you going with?
GTR
BPG is offline   Reply With Quote
Old 04-12-2014, 11:33 PM   #6
ZO6 Bryan
ZO6 Bryan's Avatar
Spec'ed it out myself with Brian Tooley's help. Let's call it a BTR stg 2.5.
Bryan 2018 ZL1 M6
Old 04-12-2014, 11:36 PM   #7
BPG
Faster than you...
BPG's Avatar
Awesome, can't wait to hear it. I've been talking with my tuner about the BTR stage 3. Pretty sure that's the one I'm going to go with
GTR
Old 04-12-2014, 11:45 PM   #8
ZO6 Bryan
ZO6 Bryan's Avatar
Good choice for max effort car. Mine will be similar but a little smaller and a couple degrees less overlap and get the intake valve closed a little earlier for better drivabilty and better low-mid-range torque.
Bryan 2018 ZL1 M6
Old 04-13-2014, 12:23 AM   #9
ZO6 Bryan
ZO6 Bryan's Avatar
There is a bolt that comes in from the side and goes in the side of the water pump as a mount for the upper pulley bracket that has to come out or else the water pump won't come off. No need to remove the whole pulley bracket, just the one bolt and leave the pulley bracket in place.
Bryan 2018 ZL1 M6
Old 04-13-2014, 12:32 AM   #10
ZO6 Bryan
ZO6 Bryan's Avatar
And these three pulleys in yellow have to come off to get access to the water pump bolts. The pulley in green can stay attached to the water pump and comes off with it.
Bryan 2018 ZL1 M6
Old 04-13-2014, 06:56 AM   #11
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
ok...it has been stated that the entire oil pan needs to be dropped to access the oil pump pickup tube retaining bolt. Do you concur?
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 04-13-2014, 08:23 AM   #12
ZO6 Bryan
ZO6 Bryan's Avatar
Yes, it's tucked up under there pretty good. Can barely touch your finger on it. Probably could loosen the oil pan and lower the front edge a couple inches and get to it without pulling the whole oil pan off. It's like the 4thgen f-body LS1s. Can't access them either. I've done C5 Corvettes and you can reach the bolt on them.
Bryan 2018 ZL1 M6
Old 04-13-2014, 08:38 AM   #13
Stephen12ZL1
Drives: '21 ZLE A10
I had an 02 Z06 and could access this bolt without dropping the entire pan...was wondering if the LSA was more difficult. Thanks for the info above.
Old 04-13-2014, 08:43 AM   #14
snake411
snake411's Avatar
Drives: 2012 ZL1
Great post, i am going to check it out i am planing to swap mine soon
snake411 is offline   Reply With Quote
