![]() Drives: 2010 ''RS1'' my own package Join Date: Aug 2010
Install, 3D Carbon Fender Vents
here is my next mod, 3D Carbon fender vents. ill post pics of the install as I do them. but for now here is what you get. the template is not in the pic.
what they forget to tell you is that you need to remove the lettering from the fender. I used a piece of fishing line to go behind the letter and just saw back and forth and it will release the letter, I did not even have to use a heat gun, the heat from driving home from work did the trick. after you have them off all you need to do is clean the tape left overs with some thinner. then here is what you end up with. then it says to measure from the tip of the top of the fender to the body line at 12" but its more like 12 5/8, and I am going to set it forward about 1/16 of the door line just to give a bit of room for the door to open without hitting it. it wont hit but its just for my peace of mind. lol and this is where the template will go to be marked and cut out. not cutting it out yet, need to get the painting done first.
2010 1LT A6, Hurst shifter and handle, 3pc rear spoiler, streetscene splitter, ss front end with ZL1 grill, ABL , footwell and cup holder lighting, ss cat back exhaust, Eibach lowering springs, custom engine cover, 4pk gauges, speedhut A pilliar pod and gauges, metra kit and kenwood stereo, 2014 ss hood scoop with stock rain tray, 3D Carbon fender vents, rear lighted bowtie, and ultra gauge.
![]() Drives: camaro rs Join Date: Dec 2013
nice!!!!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Evil Eva, 2010 2SS LS3 Join Date: Aug 2013
Good luck, I want to see how this turns out.
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
I have thought about those... Cool man I am sure you will get it right. Are you going to paint them yourself?
Depends on how backed up my paint guy is.
#6 |
parts are coming back today, will post pics and then on to the install
here are the painted parts
#7 |
![]() Drives: SS Join Date: May 2013
Very nice. Can't wait for results.
2013 ss M6 471 / 428 adm intake / texas speed 1 7/8 long tubes no cats / npp / slp underdive pulley / cordes performance defibrillator cam / ported throttle body, intake manifold by CPR tuning by nic D
#8 |
finished
here are the pics from the install
this is with mesh and 3m tape installed, be sure to use the promoter before putting the tape on the part and on the car before putting the part on the car. I bent the edges of the mesh over flat so I could put some adhesive so they never come loose. once the template has been put up and marked then tape off the cut. drill a starter hole in each corner and now there is no going back!!!! this is the hole cut out. be sure to spray the inside of the hole black so nothing shows. and the vent in place. sets really flush to the car. looks really nice. let me know what you guys think.
#9 |
Looks great. Awesome install. I was curious how flush they sit. Great job man
#10 |
![]() ![]() ![]() Drives: 2010 Camaro SS/RS LS3 Join Date: Apr 2013
Nice job, looks great!
#11 |
Thanks, this is a lot simpler than it looks. And the effect it has on the car is awsome!
#12 |
Member Club Elite #131
Drives: 2017 50th Anniversary H50 2SS Join Date: May 2009
Looks Great. Your braver than I am, I don't know if I could cut the fenders like that.
It turned out great.
#13 |
thanks, it wasn't that bad cutting up the car.....lol
#14 |
Looks good man.
