In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
Un-Official V8 Fast List Closing
I'm considering ditching the Un-Official V8 Fast List. The original purpose was for those members at altitude tracks to hold a spot some where on a C5 fast list. Almost all the usual suspects at the top of the Official List's are holding spots on the Un-Official list as well. There are two ways to correct it:
1. One list only per member either Official or Un-Official. 2. Remove the Un-Official List's all together. I prefer option 2 as I don't believe the list is being used for what it was intended for. Comments?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
I feel for you guys at altitude. I think you should be allowed to convert your times to sea level for the official list.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
![]() Drives: 2011 Camaro SS L99 Join Date: Jan 2012
It would suit me either way.
#4 | |
In The Circle
Sorry, but that's not an option I'm considering.
![]() ![]() ![]() ![]() Drives: 67RS Camaro ,Black 2013 ZL1 Join Date: Jun 2010
How about deleting the unofficial and adding a column in the official category with a corrected time. It would not change your position on the list but would be there for the what if factor.
Keep up the good work Merc. See ya in Texas.
#6 |
Emerald Coast Camaros
Drives: 2010 RS/SS Rally Yellow & 68 SS Join Date: Dec 2012
Option 2 is good
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135 AS OF 1/31/15 @ 633 RWHP=10.16@135 AS OF 1/29/16 @ 633 RWHP=10.10@136 TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: none Join Date: Aug 2011
#8 |
![]() ![]() Drives: 2012 Camaro SS 45th Join Date: Oct 2011
If its unofficial then axe it.
OBX 1 7/8 LT's w/high flow cats. Doug Thorley catback w/x pipe. Cold air intake by CAI w/apex scoop.V-max ported throttle body.DynoSpeed tuned by Forest.369 rwhp/385 rwtq
Something wicked this way cometh... |
#9 |
10.11 @ 136.32
Drives: Black & Yellow 2SS/RS LPE LS7 427 Join Date: Mar 2010
I never peek at it so I'm good with ditching it. You're call Merc.
Bryan
#10 | |
In The Circle
#11 |
Only drives on Sundays
Drives: '16 2SS A8 NPP MRC NGray Join Date: Feb 2011
I know it's hard to change the format, but my vote would be for adding a Density altitude column. Not everyone knows or checks, and it wouldn't always be exact or verifiable, but regular racers would understand the significance.
Another option would be to add a new list entirely to the official list, and call it the "Mile High Club". There are only a few true mile-high tracks, so I would make it for people who have raced at tracks above, say, 3500 feet. This would allow people who race in the high deserts to post times (e.g. West Texas, AZ, NM, CO, NV).As a former El Paso racer, I know the frustration of altitude. Padre |
#12 |
HARD WORKING PATRIOT
Drives: 2011 CAMARO 2SS RS-AUTO Join Date: Oct 2010
Been chewing away creating a response, here you go- hold on.
MERC, We thank you for spending the time that you do on the lists. Thanks to those reading my novel- I wouldn’t have spend this time if I didn’t feel it was important for the group. As we know, there is quite a bit of time / history in them and for some submissions the Corrected ETs are the only way on the 'boards'. This is due to the original no red light rule of the Official list and from those that are less fortunate to get access to great DA. I would prefer not to see those entries and people be disregarded in such a manner. As a good example, my first outing this ’14 year just last Saturday was a dismal 2.5 times worse DA than my Official PBest, but my Corrected ETs were spot on- so still a great tool for evaluation. We have discussed and understand that the Drag times DA isn’t always accurate and thus the Corrected times could be a little off, but they are still of good use. Not only does it provide high altitude racers a place for them, to me it's really a good place to learn what car mods are producing in order to help set goals and to see how their cars are running- comparing to zero DA. I would suggest if the Unofficial list is not able to be maintained as a separate list, that it would just be Closed, but not deleted. It would still provide some purpose. I would also recommend that if it does, its noted in the first post in big bold that it has been closed x date and may not reflect current 'corrected' leaders. Please consider Option #3 (like Trackmans). First before you react, remember that you have a family here that can help. No one expects a one man show. So with that in mind, I am suggesting the following and offering my time to complete the changes: 1- Close the Unofficial list, update the post#1 to say its closed and to see Official (with link). 2- Change the Official Fast list’s first post with a statement in bold to Mandatory include the DA of the future runs submitted. Optional to provide Corrected ET, if interested. Provide link to Drag times 3- The default 'Race DA' column of the run is prefilled as '-1000", changed only if submitted with info (person in charge of list should not have to look it up). This will assist in ensuring those too busy to spend a minute to look it up, their number will be looked at as of lesser relativity, since DA was superb. 4- The 'Corrected ET' column is prefilled as ‘20’ seconds. This will provide those not interested, to be placed together at bottom of Corrected Order sort pile. Down the road, then everyone submits in just the Official list with DA and Corrected ET(if desired) and it would only take a couple seconds to add the info to the table. This would allow the Corrected ET times to be number ordered simply by a Sort of the Corrected ET column, adjusting the number, then re-sort by the Official numbering order columns. I am offering to: 1- Create the new columns for each table. **2- Merge the Unofficial lists into the Official lists and adding any DA and Corrected ETs into the column. To provide some relative data for comparison: **3- Where missing, look up and add the DA of the current top 20 of each Unofficial Corrected list, from the post entries, provided that the time slips provide adequate date info. **4- Where missing, look up and add the DA of the current top 20 of each Official list, from the post entries, provided that the time slips provide adequate date info. **5- Look up and add the Corrected ET of the current top 20 of each Official list, from the post entries, provided that the time slips provide adequate date info. 6- I can make the Excel file column sort adjustment and re-ordering anytime for you if you need assistance. I would also look for support from other Excel savy forum members here to assist in the file updates and or DA look ups. **Perhaps one person per list. If no other help is offered, I would still take it on myself for the good of the group. I fully understand the task this would entail, so it would take some time with my work, race schedule, spring home cleanup, and limited internet. Sincerely, Tim
Long time avid daily reader -thanks to all for your helpful threads!
Bolt ons, Stock Torq Converter - 11.810 & 116.21 |
#13 |
In The Circle
Tim
Just to clarify thing's I was not planning to delete the list just close it and not maintain it anymore. At the end of the day not many members currently use it anyways and ET records are never corrected in any sanctioning body. There are a number of other issues as well: DA Calculator is wonky at best, cause anytime I run Pumpkin at MRP I compare to our weather station which I know is dead on and there is always a big difference. It's sometimes hard enough to get members to post the timeslip in a proper manner and now add DA Calculator to the mix will only complicate the process more. I sure don't have the skills with excel to make it auto calculate. I sure do hear what you and others are saying and I appreciate your offer to help, but like you say it's just coming up on yard work, racing, cruising and fishing season and to embark on a new way of keeping a corrected list is really not high on my list of things to do. But certianly could be looked at in the off season.
#14 |
Most hated in NM....
Drives: Sold the 6POINT2, went to a 50THZ06 Join Date: Sep 2011
High DA people need to move. End of thread
