Old 04-14-2014, 03:38 AM   #1
Redslayer15821
Redslayer15821's Avatar
Drives: 2017 2SS (50th Anniversary)
Door light strip went out is this a simple fix?
So the light on my 2013 door panel went out. Is there any way I can fix this myself? I'm in Italy now so the list of trustworthy dealers slash mechanics is very small.
Redslayer15821 is offline   Reply With Quote
Old 04-14-2014, 08:10 AM   #2
jrhagen
Banned
Drives: Camaro
Pull the door panel and check the wiring.
jrhagen is offline   Reply With Quote
Old 04-14-2014, 12:03 PM   #3
serows1
serows1's Avatar
Drives: Blue Ray 2SS
Typically it's the single LED that is the problem whether it's a connection or burned out, I've only seen one go bad so far.
I tried to copy/paste the repair instructions but I can't get the pictures to appear and the instructions are pretty useless without them, sorry.
Paul
serows1 is offline   Reply With Quote
Old 04-14-2014, 02:40 PM   #4
Redslayer15821
Thank you both for your reply. Paul if you could maybe point me in the direction of the source for the repair instructions that would be greatly appreciated.
Josh
Old 04-14-2014, 08:43 PM   #5
serows1
serows1's Avatar
Josh, here are the instructions on how to remove the door trim panel and how to remove the light pipe. I'm not sure you will need to remove the light pipe, the LED plugs into the end of the light pipe and is available in two colors for that year, red/orange and blue. Good Luck.
Front Side Door Trim Panel Replacement
Front Side Door Trim Panel Replacement Callout
Component Name
Preliminary Procedure
Remove the radio front side door upper speaker grille. Refer to Radio Front Side Door Upper Speaker Grille Replacement.
1
Front Side Door Inside Handle Bolt Finish Cap
Procedure
Use a small flat bladed tool at the front edge of the cover to aid in removal.
2
Front Side Door Trim Fastener (Qty: 4)
Caution: Refer to Fastener Caution.
Tighten
2 Y (18 lb in)
3
Front Side Door Pull Cup Fastener
Procedure
Remove the front side pull cup liner to access the fastener.
Tighten
2 Y (18 lb in)
4
Procedure
  1. Use a door trim tool or equivalent to aid in the removal of the door trim.
  2. Disconnect the inside handle release cable from the trim panel.
  3. Disconnect the electrical connectors.
  4. Transfer parts as required.
Front Side Door Map Pocket Illumination Lamp Replacement
Front Side Door Map Pocket Illumination Lamp Replacement Callout
Component Name
Remove the front side door trim panel. Refer to Front Side Door Trim Panel Replacement.
1
Procedure
  1. Disconnect both ends of lamp from the light pipe.
  2. Disconnect wire from eight integral clips.
Paul
Old 04-15-2014, 04:56 AM   #6
Redslayer15821
Paul,
This is awesome and will prove more than helpful. Thank you very much.
Josh
