![]() Drives: 1968 SS/RS 396 and 2013 ZL-1 Join Date: Jul 2012
Ac delco PF48 Vs UPF48R
Looking to tap into the forum expertice.......
, Getting ready for my first oil change, car has been sitting on battrery tender since late november unstarted so I figure Ill do the change before I fire her up! Just wondering if if there is a big differance in the 2 filters........ I picked up a Pf 48 with my mobil One at wally mart last night for under $4, just wondering how the rest of you guys feel about that filter.............. as a side note I will be changing the oil again in about 800 miles when i hit 1500 miles. And please hold the "you need to drive the car" remarks, my milage is super low because since purchase back in july 2012 work and other personal things filled most of my free time, so yes in almost 2 yrs I have only hit 698 miles on the odmeter.................. any feed back on filter would be great, thanks in advance.
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 ZL1 IOM Vin #169 Join Date: Jan 2011
GM recommends that you change the oil at or before 1 year of use due to it being a synthetic oil. So even in low use I woiuld recommend that you change the oil each year before you place it in winter storage. Also a catch can is a great investment for the longevity of your engine.
![]() ![]() ![]() Drives: CGM 2SS/RS, 1987 & 2014 Silverado Join Date: Oct 2010
I use the UPF48R filter and it has a higher pressure rating and premium filter media. Just make sure you enjoy the car when you do get to drive it!
#4 | |
I'll be back...
Drives: Subaru, HD Road Glide Special Join Date: Apr 2012
I have higher oil pressure with the Melling pump, so I use the UPF48R filter. For a stock vehicle that isn't being raced every weekend, the plain old PF48 filter is just fine.
Bye bye, Bumblebee!
Thank you all for feed back, I guess for the next 800 miles (or next winter storage) I will use the pf48 this time and next round get the pf48r..........
#6 | |
#7 |
![]() ![]() Drives: 2013 ZL1 Join Date: Oct 2012
actually if you will change oil that often use the non R version, if you will DRIVE THE CAR and change at factory intervals then the R is slightly better and come on theres no way you were too busy in two years to drive less than 700miles.
1150bhp Whipple 4.0 Supercharged 427ci Camaro ZL1 |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: SS 1LE Join Date: Nov 2012
So using the upf48r instead of the pf48 will not cause any warranty issues?
#9 | |
#10 |
Mach 5
Drives: 13 ZL1 IOM #115 87 Grand National Join Date: Jun 2012
I was taught decades ago to warm up the engine just before changing the oil.
Memory is sketchy as to why, something about particles being suspended in the oil making for a better drain (so that more dirt is removed by oil change) Does anybody else do this?? Also, put a few drops of oil on the new filter gasket for a better seal/easier removal next change. |
#11 | |
I can say that when we change the oil In our 10 wheel Mack dump truck we let it drain over night then again it takes like 5 gals of oil . your comment about the oil on the filter gasket is spot on been doing that since I was a kid.
#12 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
#13 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
O L D T H R E A D A L E R T
I was checking int to UPF48R filter and found this 2008 link
http://www.teamzr1.com/ubbthreads/ub...at&Number=2677 Basically the difference is a higher burst pressure rating, the internals are the same as the PF48 (Presumably migrated to the "E" non-metallic cage as the PF48E) Derived for the LS9 engine, higher flow rates and higher pressure
