Old 04-17-2014, 11:56 AM   #1
hazy
Drives: 2011 2SS/RS
What kind of times to be expected?
Apologies if this is in the wrong place...feel free to move it if needed, but I figure this is the appropriate sub-forum
So I'm going to the track with a coworker soon. Never run on a drag strip before, so it's going to definitely be a learning. I don't expect that I can really run this car to it's full potential (launch, shift points, etc...) but curious to know what a reasonable time would be based on the mods for the car. I figure my first few passes will be terribly slow just so I can get used to going down the track, and then will start trying to ramp up the speed, and get the times down...it'll be running on street tires
Specs according to shop that put it all together (510 Racing):
416ci low comp motor (9.3:1, I believe? prev owner was bldg it for an S/C, hence the low comp)
cam (unsure of details, but it's fairly lumpy, though not terribly lumpy)
Ported LS7 heads
Roto-Fab intake
Kooks long tubes
Corsa exhaust
Katech LS9R clutch
Factory installed Hurst short-throw
the guy at 510 that I talked to couldn't remember an exact HP figure, but he said that he thought is was around 480-490 at the rear wheels. I've yet to have it on a dyno since purchasing it.
SO, all that being said...what do you think this could do with an experienced person behind the wheel? How about with a not-so-experienced one, such as myself?
hazy is offline   Reply With Quote
Old 04-17-2014, 12:12 PM   #2
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
Experienced maybe high 11s not so mid 12s
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 04-17-2014, 01:12 PM   #3
hazy
Drives: 2011 2SS/RS
oh wow! that's hella quicker than I would've thought...though, being totally inexperienced (outside of some occasional spirited driving on the street) I'll be floored if I can break into the 12s on the first trip out Something to look forward to!
Thanks!
Old 04-17-2014, 02:24 PM   #4
Mr. Nasty
Mr. Nasty's Avatar
Yeah I would think at least mid 12s. Just need to get some seat time in. When you make to the track let us know how it go's
Old 04-17-2014, 09:13 PM   #5
Fraxum
Fraxum's Avatar
Drives: a M6 LT1 ordered From Becky!!!
OP you will need some DRs. I think with practice you can do better than high 11s. In the beginning or with street tires 11s will be very far away.
Old 04-18-2014, 05:59 AM   #6
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
I agree, the car itself can do better than high 11's, the lack of racing experience will be a learning curve for a while so just give it time and take notes from each trip.
Good luck.
Camarojt is offline   Reply With Quote
Old 04-18-2014, 09:57 AM   #7
Mr. Nasty
Mr. Nasty's Avatar
OP don't get me wrong if you get the car set up and dialed in with some seat time yeah low to mid 11s at that HP. But it takes more than HP to make the car fast down the track.
Old 04-18-2014, 10:22 AM   #8
Bo White
Bo White's Avatar
Yeah, low 12s shouldn't be a problem on street tires.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 04-21-2014, 11:38 AM   #9
hazy
Drives: 2011 2SS/RS
oh yeah, I'm not expecting low times at all initially...I figure after many runs I'll be more comfortable on the track, but my current level of experience [zero] is such that I'm sure I'll be lucky to have those kind of times anywhere in the near future
Hoping to get out on the track either this weekend or next at CFest! We shall see how it goes!
Old 04-21-2014, 06:43 PM   #10
2010SSRSM6
2010SSRSM6's Avatar
Where you are in a manual car and unless you are very skilled, don't get your heart set on anything faster than mid 12's. This car will crush your dreams unless you are on your game in a M6.
Getting quick times in a M6 is a lot harder than in an A6. My PB is 11.80 with a lot more power than you are putting down on street tires.
