Old 04-19-2014, 03:48 PM   #1
MLAZ1990
Drives: 2012 black camaro 2LS
New TPMS not working...?
I just put my new wheels on yesterday(came with factory TPMS already installed) and the TPMS aren't syncing...
Can somebody tell me how to get the car to relearn the the new TPMS?
MLAZ1990 is offline   Reply With Quote
Old 04-19-2014, 04:06 PM   #2
Slayer1677
Slayer1677's Avatar
Drives: 2011 2SS/RS
Try deflating the tires to about 10 psi one by one. Fill each one back up. Worked for me me when I was having TPMS problems.
American Racing Headers, Magnaflow, CAI, Gloss Black Heritage Grille, SJM Autoprod lighting, River City Creations emblems, Hurst shifter, Tune by Nickey
Slayer1677 is offline   Reply With Quote
Old 04-19-2014, 07:52 PM   #3
Kid
Kid's Avatar
Drives: 2011 Camaro 2LT, 68 Camaro RS
You sure you have TPMS? I was "assured" by a member on here that the wheels I bought had them, but I pulled the tires, it was the valve stem only. Every other wheel I have syncs like Slayer said. Make sure you pull the e-brake, and hit set/clear while on the tire monitor screen. Key on, not running.
2011 Black/Inferno 2LT. Inferno Brembos, MRT 2.0, Vararam, BBK LTs, RX Catch Can, VMAX ICE-olator, VMAX P/P Throttle Body, Monster clutch, MGW Shifter, OverKill Tuned.
Kid is offline   Reply With Quote
Old 04-19-2014, 09:12 PM   #4
MLAZ1990
I have TPMs! I paid for them to be installed on the wheels when I bought them...I just need to sync them with the system...
Old 04-20-2014, 02:18 PM   #5
MLAZ1990
So I just let air in an out. I don't have to listen for any special noises or anything?
Old 04-20-2014, 02:28 PM   #6
Kid
Kid's Avatar
Turn the key to on, not running.
Set e-brake
Navigate to the tire pressure menu
push the set/clear button on the stalk.
the horn should beep twice
Let some air out of the drivers front tire until horn beeps once
Do the same for passenger front tire until horn beeps once
Do the same for passenger rear tire until horn beeps once
Do the same for drivers rear tire until horn beeps once
Horn will now beep twice
Done
Old 04-20-2014, 02:51 PM   #7
MLAZ1990
Yeah that's what I did and the horn didn't beep
Old 04-20-2014, 02:53 PM   #8
Kid
Kid's Avatar
When you push the button at the pressure monitor screen, does it ask if you want to reset?
Old 04-20-2014, 02:58 PM   #9
MLAZ1990
Nope. They are new TPMS on new wheels...you can't reset new TPMS...I'm an idiot!
Old 04-20-2014, 03:02 PM   #10
Kid
Kid's Avatar
That's weird. It should ask you if you want to reset regardless of new or old. When I switch my summer or winter tires, I have to reset them. Have you checked in your manual. Maybe the 2LS is different?
Old 04-20-2014, 03:09 PM   #11
MLAZ1990
I dot know where it is
Old 04-20-2014, 03:13 PM   #12
Kid
Kid's Avatar
Well, here is what your manual will say. No matter what TPMS you have, if you can't get into learn mode, they won't sync.
Originally Posted by SUX2BU View Post
You guys do know you can do this yourself right? Read your manual.
Old 04-20-2014, 03:18 PM   #13
MLAZ1990
I don't understand...how could this be happening? I paid the wheel place to put TPMS on the wheels...
Old 04-20-2014, 03:24 PM   #14
Kid
Kid's Avatar
The problem is not your sensors. You're not getting your car into learn mode. If you are not seeing the reset yes/no, you'll never be able to sync the TPMS.
