Team LFX
Drives: Fast Join Date: Mar 2012
I recently came across a deal I couldn't pass up. I bought a front set of Brembo brakes from a member here, and I have a couple of questions. Would I need to upgrade my rears as well? Does it cause any sort of imbalance if I don't? Also, does upgrading my rear brakes have any effect on rotational weight? Thanks.
[COTW 4/13/15]
Drives: Supercharged LLT Join Date: Jul 2010
Im not an expert but It should be fine, then again there could be some kind of imbalance like you said.V6 calipers are 1 piston while the SS's are 4 fwiw. You can find the rear brembos on amazon for cheap. Which is what i did for my brake upgrade.
