04-19-2014, 05:42 PM | #1 |
Drives: '13 Camaro 2SS/RS Join Date: Sep 2013
cai causing bucking?
Hello all,
At low speeds high gear when I punch the throttle the Camaro bucks a little. I installed cai intake not to long ago. Anyone ever experience any of this? for instance 4th gear at ~20 mph engine will bog down, obviously, but will buck a little. or 5th gear at ~30 mph when I get heavy on the throttle it bucks/hesitates a little. For all I know this is normal, I just never noticed it before. Any advice or knowledge on this subject? Thanks |
04-19-2014, 06:17 PM | #2 |
Drives: 2014 camaro ss ,1967 chevelle ss, Join Date: Sep 2013
20 mph in 4th,anything would buck under that strain
04-19-2014, 06:21 PM | #3 |
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3 Join Date: Jun 2010
What's the need for 4th at 20 mph?
Easy enough to remove the CAI and test without it
04-19-2014, 06:22 PM | #4 |
Drives: 2015 Cummins Join Date: Jul 2013
Are you sure it's tightened all the way?
04-19-2014, 06:26 PM | #5 |
Drives: 2014 Camaro SS Join Date: Sep 2013
y u trollin bro?
04-19-2014, 06:31 PM | #6 |
Buick 455 Fan
04-19-2014, 06:42 PM | #7 |
04-19-2014, 07:18 PM | #8 |
Buick 455 Fan
depends on what you mean by 'buck'
04-19-2014, 07:19 PM | #9 |
well then, his car is broke. you should try driving my chevelle like that and you'll eat the steering wheel
04-19-2014, 08:38 PM | #10 |
old school chevy rodder
my car with a cam will buck my car if I do not have it above 1500 rpm at least in any gear, if your going that LOW in the gears for MPG stop it and learn to drive a stick properly, keep your rpms above a level to avoid bucking!!! its not the CAI its YOU!
2021 Wild Cherry ZL1 A10, Sunroof, Data,Red Carbon Interior, Nav, RotoFab Big Gulp , Elite x2ultra, Borla ATAK, Driveshaft shop, full BMR susp, Speed eng. valve covers, intercoolers, ATI , 2650 MAG, DSX lid, 103 NW, JBA shorties, Lingenfelter check, 1le wheels, spoiler and diveplanes, PCV, Big3racing ice tank, [SIGPIC]etc....
04-19-2014, 08:41 PM | #11 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
You're bogging the engine... of course it bucks and lags lol. If you need to accelerate, downshift. My car bogged at 30 in 5th until I had all of my mods into it, and even then I never stay in 5th if I have to accelerate fast.
04-19-2014, 09:16 PM | #12 |
i know that was just an example, but why would you do that? i get people at work complaining about noise when steering while sitting still, wth?
04-19-2014, 10:40 PM | #13 |
Drives: 2011 1SS/RS LS3 Join Date: Dec 2012
Check to make sure your MAF is tight, mine was lose after I installed a CAI and I had a similar problem, also a very rough idle. If the MAF sensor is tight, you're probably just bogging the engine down, no big deal just keep the RPMs up a little bit
CAI intake, apex scoop, Vmax ported TB, MGW short throw, BMR 1" springs and sways |
04-19-2014, 11:08 PM | #14 |
Bad 45th
Drives: 2012 45th Anniversay Edition SS Join Date: Apr 2014
Does it do this when the RPM's are up? Or at faster speeds? It really sounds like your trying to accelerate in gears too high for the RPM's your going.
- Carl
2012 45th Anniversary SS - LS3 Magnuson TVS 2300 Supercharger / Alky Meth Injection / Lingenfelter GT12 Cam / Kooks LT Headers, 3 inch exhaust & QTP electric cut outs / Monster LT1-S Twin Disc Clutch / MGW flat blade short throw shifter / Haltech CAI / VMax Throttle Body / DSS Stage 3 axles/ BMR Trailing Arms, Toe Rods, Suspension Bushing and 1" lowering springs / Taylor 8MM Plug Wires / Tuned by Henderson Performance Technologies / EBC dimpled and sloted rotors / G2 Painted Calipers / GM Tower Strut Brace / ZL1 Factory Rep Wheels |
