Old 04-21-2014, 01:17 AM   #1
CrystalRedTintcoat
CrystalRedTintcoat's Avatar
Drives: 2013 2SS 1LE NPP GBE
Lowering Springs
What brands do you guys recommend? Will these affect the 1LE handling in a negative way? 1" to 1.5" lowering?
I'm not going to pony up for coil overs.
2013 1LE NPP GBE
Mods
Track Days
CrystalRedTintcoat is offline   Reply With Quote
Old 04-21-2014, 01:33 AM   #2
BATMOB1LE
• HT •
BATMOB1LE's Avatar
Drives: 2013 2SS/RS 1LE
I went with BMR 1.4" springs. Should be going on this week. It definitely won't make any negative differences. The ride may be more stiff... But who cares? Lol!
2013 Camaro 2SS/RS/1LE - 402 of 451
"BATMOB1LE"
- Xpel Stealth Wrap - ZL1 Rockers - 18% Tint - Custom Badges - Heritage Grille - BMR 1.4" Springs - Solo Performance Axel-Back Exhaust - Recaro Sport Seats
BATMOB1LE is offline   Reply With Quote
Old 04-21-2014, 01:45 AM   #3
OzzySS
OzzySS's Avatar
Drives: 2013 2SS/1LE, 2004 Cavalier
Apex took over Pfadt's springs and have them on their website under the Apex name now, if that appeals to you
Build thread linked in the pic...
OzzySS is offline   Reply With Quote
Old 04-21-2014, 03:22 AM   #4
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
Get pfadt springs. Under the Apex name like mentioned above.
They're 1.25" all around.
http://www.apex-speed.com/apex-motor...g-springs.html
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger, Monster S Series Triple Disc Clutch | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles | Mickey Thompson ET Street R 305/45/18 |
Tuned by Ryne @ CMS E85: 734rwhp/674rwtq
Jeff_SS is offline   Reply With Quote
Old 04-21-2014, 01:32 PM   #5
canecorso69
run ur car not ur mouth
canecorso69's Avatar
Drives: 2013 1LE
I went with Pfadt and I have zero complaints. The look is perfect.
TSP headers, cat delete, x-pipe, atak, RPM custom cam and tune, Phfadt 1.25 springs, 15" Carlyle conversion, Nitrous Outlet, Procharger F1A-94, Meth inj
canecorso69 is offline   Reply With Quote
Old 04-21-2014, 01:37 PM   #6
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
What are the Apex provided spring rates front and rear?
Old 04-21-2014, 11:57 PM   #7
CrystalRedTintcoat
Exactly. It doesn't say on their web site.
2013 1LE NPP GBE
Mods
Track Days
Old 04-22-2014, 12:04 AM   #8
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Well do we know what the pfadt rates were?
Because they're gonna be the same as that, right?
Old 04-22-2014, 12:29 AM   #9
tw78911sc
tw78911sc's Avatar
Drives: 14 1SS Camaro 1LE, NPP, Recaros
what they were a couple of years ago :
http://www.camaro5.com/forums/showthread.php?t=234954
tw78911sc is offline   Reply With Quote
Old 04-22-2014, 09:52 AM   #10
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Do any of you guys know anything about 'Ground Force' lowering springs? I know a 1LE owner installed some recently and his initial reaction and review was very positive. All I know is it was a 1" drop all around. Prior to his post in 1LE facebook group, I hadn't even heard of Ground Force. Apparent they won 2011 SEMA product award.
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 04-22-2014, 10:08 AM   #11
TxBandit911
Call Me"Doc"
TxBandit911's Avatar
Drives: 2014 2SS/RS 1LE BLACK
I've heard BMR 1" springs with good results.
TxBandit911 is offline   Reply With Quote
Old 04-22-2014, 12:58 PM   #12
29er
29er's Avatar
Drives: 14 1LE Garage King
thought the springs that got apex were all 1.4".............
i would go for 1 to 1.25. not more.
29er is offline   Reply With Quote
Old 04-22-2014, 08:38 PM   #13
1LeSS
1LeSS's Avatar
Drives: 2013 2SS/RS VR 1LE
I went with the Pedders Sport Ryder Springs 220032/220033 and am very happy with appearance and ride. I even did the 'wife' test, took her for a ride without her knowing what changes had been made. She said it feels like it did before, did you change anything?
I also added the pedders permagrin kit. Yes, it does give you permagrīn.
1LeSS is offline   Reply With Quote
Old 04-22-2014, 08:44 PM   #14
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
These are what I really want. Can these still be purchased from anywhere?
