04-23-2014, 11:17 AM | #1 |
Drives: 2014 2SS/RS 1LE Join Date: Nov 2013
Kooks header question
Did any of you guys use the gaskets that came with the headers or did you get another set from GM? Also did you use the header bolts that come with or did you get others like ARP? I just wanna make sure I use quality! Thanks
04-23-2014, 11:22 AM | #2 |
Lifestyle = Deathstyle
I bought new gaskets from dealer - OEM are the best. Re-used the header bolts.
11 2SS/RS
04-23-2014, 11:44 AM | #3 |
Philippians 4:13
Drives: SLP Supercharged LS3 Join Date: Aug 2009
I bought om gaskets but used the header bolts that cane from kooks.
04-23-2014, 11:52 AM | #4 |
Drives: '69 SS Convertible Join Date: May 2009
I reused both the OEM gasket and the bolts. My car only had about 3,500 miles at the time. I had no issues with it.
Build Journal |
04-23-2014, 02:58 PM | #5 |
10-bolt Destroyer
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M Join Date: Jun 2012
I reused the stock OEM gaskets and the stock OEM bolts that were on the stock manifolds.
Absolutely no leaks and after 2 weeks i went to re-tighten the bolts but they were still tight. My 2 cents, dont waste the money. Just be careful during diss-assembly so you dont break anything. Pull the spark plugs out before you remove the manifolds so you dont accidentally crack one (super common) and youll be good to go!
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq |
04-23-2014, 09:50 PM | #6 |
Drives: 2012 ZL1 & 2010 2SS/RS Join Date: Jul 2009
The bolts are good. Gaskets are not. I would reuse or get new OEM gaskets.
04-23-2014, 09:52 PM | #7 |
Same here. Re-used OE gaskets but I used the new bolts.
2010 SS/RS M6-LS3 -- Mods -- CAI, V-Max Throttle Body, Apex Scoop, SP 1 7/8 Headers, HF Cats, Magnaflow Tru-X.
Dyno Tuned by Mike (FAST Automotive) and Matt (FSP) BMR Suspension - Rear - Cradle Bushings (Pro Version), Upper Control Arm Bushings, Diff Bushings, Trailing Arms, Toe Rods, Drop Spring, Koni STR.T Struts. |
04-24-2014, 08:26 AM | #8 |
Senior Camaro Fanatic
Drives: 2011 SS/RS manual - White Join Date: Aug 2010
I reused the OEM, but one side leaked. Bought new OEM, all good. I do believe one side is very slightly warped though (bought the headers slightly used)
Former '68 and '69 Z/28 Owner...........Now sporting around in a 2011 RS/SS with........Kooks LT's and cats, JRE tune, CAI, scoop, ZL1 Bumper conversion, custom ZL-1 grille, halo harness, Painted silver stripes, GM GFX, black painted lower edge of skirts and rear bumper. MGW shifter.....and now a 3.91 1LE diff
04-24-2014, 08:46 AM | #9 |
Drives: E92 BMW M3 Join Date: Oct 2012
I bought new as they are designed to compress when installed. Most have no issues reusing, but they are cheap so no question to buy new OEM for me.
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned |
04-24-2014, 11:38 AM | #10 |
New OEM gaskets are cheap insurance against leaks. Some can get away with reusing them, but for the risk of having to go back and replace them if there was a leak, It's just not worth it IMO. The hardware that comes with them is good, but definitely pick up some new gaskets.
Best regards, Tyler 888-308-6007 |
04-24-2014, 07:26 PM | #11 |
Drives: '11 2SS/RS A6 Join Date: Apr 2011
Use OEM gaskets - new or used and re-use stock header bolts. It's also a good idea (but not necessary) to put a little anti-seize compound on the bolts when you install your headers.
Performance Mods:
Kooks 1-7/8 LTs; Calico coated w/HFCs, Solo Mach XL catback w/J-pipes, VMax TB, C.A.I. Intake, JRE Tune, RX Catch-Can |
