View Poll Results: your clutch fluid color
apple juice 11 50.00%
olive oil 4 18.18%
see-through 0 0%
BLACK AS DARKNESS 4 18.18%
grape juice 3 13.64%
Voters: 22. You may not vote on this poll
Old 04-29-2014, 07:35 PM   #1
a7m1
Drives: Camaro SS M6
Exclamation Post your clutch/ brake fluid color (ls3 tr6060)stock drivetrain
here's mine single brake and clutch reservoir * IN ATTACHMENT)
4000 miles on the clock ,did one partial exchange with delphi dot4 before that in ~ 500 miles (sucked probably 2/3 of the reservoir)
today i tried to suck as much as i could then refilled with wagner dot3
notice immediate difference in shifting 2nd, 3rd gear
will do another oil exchange soon to maintaim the color probably bleeding it later although i believe i have no bubbles
my driving style is cruisig arround
state weather your reservoir is combined or seperated
your driving style
recent oil change and method, (suck, fill) (bleeding and flushing)
thanks.
a7m1 is offline   Reply With Quote
Old 04-29-2014, 09:33 PM   #2
mp51998
mp51998's Avatar
Drives: Black 2011 2SS/RS
Mine was blacker than night until yesterday. I bled it all out. Fortunately I'm running a separate reservoir. Got about 5000 miles since last bleed.
mp51998 is offline   Reply With Quote
Old 04-29-2014, 09:38 PM   #3
a7m1
Talking
i am big believer in combined reservoir
less parts(simplicity)
higher volume( good for cooling)
easier to read the level
after all? brakes dont pollute the fluid right? i mean under normal braking without boiling fluid
brake dust won't get through seals right?
the only downside is that clutch dust is bad for abs module
Old 04-30-2014, 06:56 PM   #4
a7m1
bump
Old 04-30-2014, 09:41 PM   #5
mp51998
mp51998's Avatar
[QUOTE=a7m1;7624224]
the only downside is that clutch dust is bad for abs module./QUOTE]
I've bled my clutch reservoir at least four times since having it but have only bled out my brake fluid once since switching to Motul. So the nasty fluid I took out of there would have been in my brake fluid. I feel it's worth it but I can see your point as well
Old 05-01-2014, 07:17 AM   #6
a7m1
[QUOTE=mp51998;7627427]
exactly , yes sure it worth it
each reservoir should be for specific reaaon, combining them is never good (even though thefluid formula is the same)
so brakes fluid will not get contanimated at all( except from humidity and water?)
does brake pads dust gets through seals and contanimated the fluid?
so here clutch dust interfaring with abs operation is the only thing to worry about?
thanks,
another question
is sucking all the fluid through soap dispenser straw gonna get air to the systrm(brakes or clutch) then immediatly filled it ?
or only if clutch is operated while reservoir is empty( i never did that)
thanks again
Old 05-01-2014, 08:45 AM   #7
Bo White
Bo White's Avatar
Mine at 23k miles when I put my remote clutch rezzy on:
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 05-01-2014, 11:30 AM   #8
a7m1
OMG!!!
Old 05-02-2014, 03:06 PM   #9
a7m1
please post pictures for users who voted !
Old 05-09-2014, 07:53 PM   #10
a7m1
bump.
change, clutch, color, fluid, oil
