Old 04-29-2014, 08:29 PM   #1
ddck24
ddck24's Avatar
Drives: 2012 Camaro 2ss 45th M6
M6 launch on drag radials
Track trip this last weekend was a disaster...
Car would hook solid and just fall on its face.
I am running a 3.42 rearend w a mantic9000 clutch.
I even tried revving to 4k rpms still hooked and fell on its face..
Anyone have tips for getting a m6 w a grabby clutch like the mantic outta the hole hard? Was at my wits ends.. Haha I know w some practice ill eventually get better, but man it's frustrating!!
Btw it's a ysi car, with 17" 295/45 et street II's at 16psi cold.
ddck24 is offline   Reply With Quote
Old 04-29-2014, 08:36 PM   #2
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
More air in the tires and a higher rpm launch
ttshovel is offline   Reply With Quote
Old 04-29-2014, 09:09 PM   #3
ddck24
ddck24's Avatar
True^^ will try bout 20psi next time out and adjust from there
To be honest I was dumbfounded when it dead hooked (never had that problem haha).. Couldn't hardly believe it
Old 04-29-2014, 10:18 PM   #4
Turbo99
Turbo99's Avatar
Drives: 08' F250 Diesel & 10' Camaro 2SS
I ran my Mickey Thompson DR at 17psi and launch about 4200-4300 before I put some more gear in the car.
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph
TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets
Turbo99 is offline   Reply With Quote
Old 04-29-2014, 11:06 PM   #5
Bo White
Bo White's Avatar
4500-5000rpm is what Ive understood for successful launches.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 04-29-2014, 11:08 PM   #6
ddck24
ddck24's Avatar
Dang Bo.. Will have to giver her a little more steam then.. Lol
Old 05-01-2014, 12:00 AM   #7
Fallout
Mid Florida Camaro Club
Fallout's Avatar
Drives: 2012 Camaro SS Ashen Gray
I gave up, 4l80 & slicks FTW.
ECS 1500 supercharger blacked out, Alkycontrol, Livernois Duel Pumps, PRC 255cc aftermarket heads, FSP cam, DSS 9" with 3.55, ARH headers, magnaflow exhaust, Century Level 5 4l80
741 RWHP and 602ft-Lbs
Built By Florida Speed and Power
Coming soon YSI and to the moon
Fallout is offline   Reply With Quote
Old 05-01-2014, 02:11 AM   #8
striker1703
striker
striker1703's Avatar
Drives: 2010 Camaro 2SS
Did it look something like this? I struggle with a similar problem.
YSI - M6 with Mcleod RXT.
About 10 passes on this set up and I still cant get better than a 1.9 60ft -11.5 @ 128 with 18in F14 nitto NT50R
disregard comments on video, its not a pro charger but a vortech ysi
striker1703 is offline   Reply With Quote
Old 05-01-2014, 12:26 PM   #9
swiftkart
swiftkart's Avatar
Drives: 2010 SS/RS LS3 M6
Mantic900 here and no problems being grabby, 4,000-4,500rpm and slip it right out of the hole, 700rwhp maggie, slipping it off the line is the key, the clutch will handle it very well.
swiftkart is offline   Reply With Quote
Old 05-02-2014, 12:02 AM   #10
chalhoee
chalhoee's Avatar
Drives: 2010 M6 2SS/RS
I'm exited to throw a RXT on my car along with some Stage 4 Axles! Before I was launching at 4k off the 2-Step on 555R's (stock clutch, stock rear-end) best time has been 12.7@117 .. over 4k altitude though
SW 2010 2SS/RS
Currently at 608whp/701tq
-229/236 CAM-VR-BBK LT's-Vmaxx TB-O/F Xpipe-LM2's
-LS3 ported heads/Mani
-Wet Nozzle 150 shot
-Tuned by Solid Tech Performance (ABQ, NM)
chalhoee is offline   Reply With Quote
Old 05-02-2014, 11:11 AM   #11
Powhusku
Powhusku's Avatar
Drives: 2010 2SS/RS M6
Guess I should watch this thread. In the process of putting on a V3si and a Mantic 9000 with 3.91s and the same tires on my wishlist. I guess the consensus is around 20 psi in the tires and slip out at 4500-5000?
Powhusku is offline   Reply With Quote
Old 05-04-2014, 11:31 PM   #12
caverman
caverman's Avatar
Drives: '69 SS Convertible
I don't know that I would say the consensus is 20 psi. I ran the other night on some used 18" MT ET Streets at 17 psi. I also use a Raptor shift light to help launch. Leaving at about 4K was the best for the night but I think I'm going to go up to 4200 - 4300 next time. With a decent burn out I never spun nor bogged down.
Build Journal
Old 05-05-2014, 11:24 AM   #13
ddck24
ddck24's Avatar
What was your 60'??
Old 05-05-2014, 03:03 PM   #14
caverman
caverman's Avatar
The best I got for the night was 1.93 60'.
I didn't really get as good of a burn out as I wanted though. I was trying to get a routine going and the first few runs I would goof something up. Anything from not setting the brake pressure good enough, to not getting both tires wet so it would get sideways on the burnout, to not getting the RPMs up high enough.
I think once I get a good routine down and find the best way to launch I'll bring both the 60' and ET down.
Build Journal
