Intercoolers: Black or Unpainted?
Trying to decide which way I want to go. Can anyone think of any aesthetic advantages for one or the other? Post pics of yours!
Drives: 2x 05 Vettes/65'AC cobra/68 camaro Join Date: Apr 2009
IT comes down to if you want to see it from the front at all or have it blend in
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
Mine is natural, as you can see you really cant tell except on a straight shot look that theres one there.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Personally, I wouldn't paint it. It's a part that's sole purpose is to get rid of heat. Anything you cover it with will compromise it's ability to do so, to some degree. It may be negligible, but it's just the principle of it. If I HAD to do it, i'd tape off the fins and just paint the endtanks.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
Drives: 2010 zr1 Camaro 2011 vert Join Date: Apr 2013
There is a coating that can be applied that helps cooling even further that is black
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2006 Z06 Join Date: Oct 2010
Like H-E said there is a special heat disappaiting coating that can be applied that actually helps. Just covering it in normal black paint does not help.
Nick
Corvette Z06 -1200ish rwhp |
#7 |
![]() ![]() Drives: 2011 Camaro 2SS/RS Join Date: Oct 2011
I like mine to be seen
#8 |
striker
Mine was black and I had it unpainted . Personal preference as I wanted it to show through the grill.
#9 |
![]() Drives: 2010 Aqua Blue Camaro 2SS/RS Join Date: May 2013
Mine has the black coating on it that H-E was talking about ^
I wanted it to be silver but IPS took forever with building my kit so they coated all the hot side pipes with that stuff for free. I wish they would've left the intercooler though beacuase even knowing it's there I can barely see it. So I voted silver cause that's how I wish mine was..
#10 |
Unless you're paint has thermal barrier properties (most do not) then a black paint will transfer heat better. Simple heat transfer characteristics for radiant heat from a black body versus a silver body. (Maybe not so simple, having sat through way too many heat transfer class lectures!) Forced conduction heat transfer is probably not affected by most paints, so why not take advantage of the radiant heat transfer properties of a black body?
Past: '69 Chevelle SS396 '79 Camaro 400SBC/TH400 Present: '14 Camaro 2SS/1LE '03 Avalanche (tow car for...) Twin-turbo SBC Super Comp Dragster Future: FFR 33 Hot Rod w/ SBC RCR GT-40 w/ LS7 |
#11 |
![]() Drives: 2012 Camaro 2ss 45th M6 Join Date: Jun 2012
Black.. Less people can see it the better
#12 |
![]() Drives: '11 Camaro Supercharged Convertible Join Date: May 2014
I went with silver. Took a buffing wheel to it, and now it shines, which is my preference.
2011 Triple Black SS convertible, LSX 427, PRC 260cc heads, Callies Ultra Billet Rods, Wiseco -20 cc piston, Callies Dragon Slayer crank, Strange Dana 60 rear w/3.73 gear ratio and driveshaft, Pfadt coilovers, Pfadt sway bars, Pfadt trailing arms, Pfadt tie rods, Pfadt subframe bushings, Vortech YSi with wastegate and twin BOV, Haltech ECU, Mantic 9000 Twin Clutch, ALKY control meth system with dual nozzle, Squash twin fuel pumps, ACS T3 ports, VIS Terminator Hood, Seibon ZL style lip.
#13 |
Blaaaaack
obviously not totally scientific, but the results are interesting. |
#14 |
Master Amateur Mechanic
Drives: Victory Red 2011 2SS/RS Join Date: Jan 2013
MCM proved that black has gains. black if you wanna spend the money
