Old 04-30-2014, 11:53 AM   #1
Eteam
Drives: 2014 Camaro 2lt rs
CAMARO FOSGATE SET UP HELP PLEASE AMP PROB
Hello I wanted to know what amp I can use for this set up? Sepperate amp for the subs. and how would I conect the amps to the factory chevorlet 2014 camaro my link? And how would I connect the 4 tweeters to the amp?
2xFront door https://www.sonicelectronix.com/item...wer-T1675.html
2xBack deck https://www.sonicelectronix.com/item...wer-T1693.html
1xFront deck https://www.sonicelectronix.com/item...unch-P132.html
4xTweeter https://www.sonicelectronix.com/item...ate-PP4-T.html
2xSubs Rockford Fosgate P3D4-10 Punch P3 DVC 4-Ohm 10-Inch 500-Watt RMS 1000 Watts Peak Subwoofer by Rockford Fosgate http://www.amazon.com/dp/B004UFHXOC/..._qUrytb0CZFRJJ
Eteam is offline   Reply With Quote
Old 04-30-2014, 04:23 PM   #2
jeffa
Drives: 2014 2LT/RS Ashen Gray Metallic
My advice, if you have not done any audio installations before, is to have the product professionally installed.
jeffa is offline   Reply With Quote
Old 04-30-2014, 07:21 PM   #3
Eteam
I am I just want to know what I'm talking about when I get there and have the parts in hand.
Old 04-30-2014, 07:41 PM   #4
436SS
436SS's Avatar
Drives: 2010 1SS
Let us know how your purchase from Sonic goes. Their prices seem to be pretty reasonable.
436SS is offline   Reply With Quote
Old 04-30-2014, 08:39 PM   #5
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
If you have it professionally done, they will create or have everything needed. Some shops won't install (and definetly won't warranty) customer supplied parts.
The front and rear speakers both contain tweeters. I don't know why you would want or need additional tweeters.
The typical install when upgrading amp/speakers is to eliminate the dash speaker.
For amp install, you would need a harness such as the ******** FARK harness, or let the installer create their own.
You're also going to need one, if not two amps and a sub box.
JimE is offline   Reply With Quote
Old 04-30-2014, 09:23 PM   #6
Camaroshark
Drives: 2010 Camaro 2SS/RS RJT, 6speed
If your car has the boston system, you need to go with the ******** FARK harness.
Don't let one of those cheesy shops chop up your wiring in the Camaro.
The ******** kit allows you to plug and play aftermarket amps and all you need is to run power and ground. You can even use the pre out on an aftermarket amp to send signal to a subwoofer amp... Again running power and ground.
Get the FARK kit! You might not even want to change the factory speakers if you include a sub and do the FARK.
2010 Camaro 2SS/RS, LS3 - 6 speed. Mods, Magnaflow exhaust with resonator delete. ******** 12" stealth box subwoofer kit, Kicker 400 mono amp, JL XD 400/4 amp.
Camaroshark is offline   Reply With Quote
Old 05-02-2014, 11:33 AM   #7
Eteam
Thank you guys for the advice will let you know how everything goes but can someone please tell me what specs I need for the amps.
Old 05-06-2014, 04:16 PM   #8
Knockoutpie
Knockoutpie's Avatar
Drives: 2014 2SS RS Coupe
Looks like you're literally going for the exact same setup I did.
I installed it all myself, same subs, however, I'd change those dual voice coils 4 ohms to dvc 2ohms
http://www.amazon.com/Rockford-Fosga.../dp/B00BF6HYDE
Here's the amp, this amp is perfect for 1 SUB! JUST 1, you'll need to of these amps.
http://www.amazon.com/Rockford-Fosga...&keywords=p3d2
Any questions message me.
Knockoutpie is offline   Reply With Quote
adapter, amplifier, mylink, tweeters
