Old 05-01-2014, 07:01 PM   #1
mreyna16
Drives: 2014 Camaro SS 2SS
lighter connection problems
In my 2014 ss camaro, the lighter connector where you connect your charger or radar does not work... niether in the center console nor inside the arm rest and i think its a fuze...
should i take it in for repair or should i change the fuze myself? if so, what fuze is it?
reason i ask is my dealership is an hr away, have to wake up early and know will take a long time (i think)
mreyna16 is offline   Reply With Quote
Old 05-01-2014, 08:57 PM   #2
serows1
serows1's Avatar
Drives: Blue Ray 2SS
It sounds like a fuse, they are located on the driver side of the dash, location #17 and #18......
Instrument Panel Fuse Block
The instrument panel fuse block is on the end of the instrument panel, on the driver side of the vehicle. To access the fuses, open the fuse panel door by pulling out.
To reinstall the door, push the door back into its original location.
The vehicle may not be equipped with all of the fuses, relays, and features shown.
Fuses
Usage
F1
Discrete Logic Ignition Switch
F2
Diagnostic Link Connector
F3
Airbag
F4
Cluster
F5
Heating Ventilation Air Conditioning Controller
F6
Body Control Module 2
F8
Battery
F9
Spare
F10
Spare
F11
Spare
F12
Spare
F13
Display
F14
OnStar® Universal Hands-Free Phone (If Equipped)
F15
Body Control Module 3
F16
Body Control Module 4
F17
Power Outlet 1
F18
Power Outlet 2
F19
Steering Wheel Controls Backlight
F20
Spare
F21
Spare
F22
Spare
F23
Trunk
F24
Automatic Occupant Sensing
F25
Body Control Module 1
F27
Body Control Module 8
F28
Front Heater, Ventilation, and Air Conditioning
F29
Spare
F30
Body Control Module 7
Circuit Breakers
Usage
CB7
Passenger Seat
CB26
Driver Seat
Relays
Usage
K10
Retained Accessory Power
K609
Trunk
SPARE
SPARE
© 2014 General Motors. All rights reserved.
Good Luck,
Paul
serows1 is offline   Reply With Quote
Old 05-02-2014, 10:37 AM   #3
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Looks like there are two separate fuzes for the two power outlets. It's odd that both don't work.
So please don't get mad about these obvious questions:
1. Are you sure the device you're plugging in is working otherwise?
2. Do you know that the outlets are not powered unless the key is turned to the on position?
Rock-It Man is offline   Reply With Quote
