Old 05-02-2014, 06:55 AM   #1
ToddB
Drives: 2011 2SS Convertible Supercharged
Drilling valve cover for catch can
Do you guys with forced induction drill out the drivers side valve cover for more air. Do you drill the nipple and also the small hole inside the valve cover? Or just the nipple on the outside. Also what size do you drill it? Thanks for any help.
ToddB is offline   Reply With Quote
Old 05-02-2014, 10:47 AM   #2
ToddB
Anyone do this. I know I read it a while back somewhere but cant find it.
Old 05-02-2014, 11:07 AM   #3
Unreal
Drives: 2006 Z06
Drill out the hole inside. Or run aftermarket covers, they are cheap, or drill a hole in the top away from nipple, weld an AN bung on. Many ways to do it. Holley valve covers are ~$155 so that is the route I went.
Nick
Corvette Z06 -1200ish rwhp
Old 05-02-2014, 11:31 AM   #4
Elite Engineering
Elite Engineering's Avatar
Drives: 2010 Camaro
The drivers side valve cover PCV barb should be drilled to 1/8" to 1/4" depending on who's system your installing. Make SURE to not drill all the way through the baffle below it as oil will splash into that hole from the rocker arms.
Also, let us know what system and how your planning on routing all so we can guide you there as well.
Elite Engineering is offline   Reply With Quote
Old 05-02-2014, 12:08 PM   #5
ToddB
I have the catch can routed correct. just doing a cam now and was going to drill the valve covers as long as I have them off now. I drilled the pvc barb. what I was wondering about is the small hole on the baffle. As to weather or not you drill that hole larger? Thanks guys.
Old 05-02-2014, 03:41 PM   #6
Twin2010
Drives: 2010 twin turbo ss
Yes, drill that hole in the driver side valve cover baffle to a bigger hole. Drilled mine out but cant remember which size. The bigger you can drill it the better
Twin2010 is offline   Reply With Quote
Old 05-02-2014, 06:54 PM   #7
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
I dont believe you drill out the baffle. Otherwise you will suck in oil, or oil will splash up. Just had this discussion with my shop and they had their fabricator weld in a patch on the baffle. My baffle did have a hole in it from drilling out the barb. The bit went too deep i guess. Just drill out the barb to 1/4" or larger. That should do it.
Maybe that's the reason every 2500 miles I had a good pint of oil in my RX Monster can.
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 05-02-2014, 07:56 PM   #8
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
don't drill the baffle...just the inside of the nipple/fitting. or buy some nice holley covers...that's what I did. bam. solved.
-John S.
Old 05-02-2014, 09:09 PM   #9
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
Holley covers are baffled well and have a larger breather opening. Cleans up the coil mounts by eliminating the brackets. Win/win.
Iam Broke is offline   Reply With Quote
Old 05-03-2014, 09:23 AM   #10
ToddB
Thanks for the info guys. Putting the covers back on today
Old 05-03-2014, 09:24 AM   #11
ToddB
My baffle does have a small hole in it from the factory. I will leave it as is.
Old 05-04-2014, 07:12 AM   #12
grocerygetter
instigator
Correct. The stock baffle has the hole it is supposed to have.
-John S.
Old 05-04-2014, 07:13 AM   #13
grocerygetter
instigator
-John S.
Old 08-01-2015, 04:29 PM   #14
JMT
JMT's Avatar
Drives: 2013 1LT
PVC drill
This is a pic of what I have. 2013 v6, is it the one that needs to be drilled or is it the newer size as I bought late in the model year. If I need to drill how do I proceed from the pic? I know it should look straight and metal no 90 degree as in the pic but not sure how to proceed as this is my only car and if I need another part it won't be easy.
JMT is offline   Reply With Quote
