Old 05-02-2014, 04:57 PM   #1
chalhoee
chalhoee's Avatar
Drives: 2010 M6 2SS/RS
Burnout probs on DR's???
Anyone else have a hard time doing a burnout on DR's? If I don't pick up some water right before my stand-still attempt, my car simply stalls after I try to press the brake lightly. Its only ocassionally at the track when this happens and I've always wondered why... I turn off everything for the burnout portion and the launch portion of the pass and when I got my tune, I asked for them to take off that Torque Management bs but for some odd reason it still does it.. especially on the street. It does it EVERY time in the street whether I have DR's or street tires!!
Am I doing something wrong or what? I usually rev up my car up to like 4k, dump the clutch (not too hard), let it go forward a little then press the brakes slightly until it just stays there burning out. Idk if anyone else has this problem or if it's just me sucking at driving but I would like to hear some feedback from my c5 fam
SW 2010 2SS/RS
Currently at 608whp/701tq
-229/236 CAM-VR-BBK LT's-Vmaxx TB-O/F Xpipe-LM2's
-LS3 ported heads/Mani
-Wet Nozzle 150 shot
-Tuned by Solid Tech Performance (ABQ, NM)
chalhoee is offline   Reply With Quote
Old 05-02-2014, 06:18 PM   #2
Juice2SS
Drives: 2011 2SS
Which tires are you running? You might just be sticking and that's a good thing.
Juice2SS is offline   Reply With Quote
Old 05-02-2014, 06:30 PM   #3
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
If you've got a manual transmission, you don't have torque management. That's only on the autos, to the best of my knowledge.
Get a line-lock - that's the easiest way to make sure you do a good burnout.
shibbs is offline   Reply With Quote
Old 05-03-2014, 12:36 AM   #4
chalhoee
chalhoee's Avatar
Running 555r's currently and I've never been able to go a stand still on the street with those. & sometimes I struggle at the track but If I pass they the water, i can do it just fine. I usually heat up my tires for a good 10-15 seconds and when I try to launch I just spin all of first... (22psi)
SW 2010 2SS/RS
Old 05-03-2014, 12:37 AM   #5
chalhoee
chalhoee's Avatar
Yeah I got the m6 but I did not know that. I thought all the Camaros had that... And that's what I blamed for my in ability to make stand stills haha thanks for the info man
SW 2010 2SS/RS
Old 05-03-2014, 08:37 AM   #6
flyby
Drives: 2010 Silver SS
Torque management IS on both Manual and Automatic.
flyby is offline   Reply With Quote
Old 05-03-2014, 10:31 AM   #7
BFASTNOTLAST
BFASTNOTLAST's Avatar
Drives: 2012 SS LS3
^^^ Brake torque in particular.
BFASTNOTLAST is offline   Reply With Quote
Old 05-04-2014, 11:01 AM   #8
caverman
caverman's Avatar
Drives: '69 SS Convertible
Time for a line lock. I just went to the track with a line lock and a set of 18" drag radials yesterday. That's the way to go.
Build Journal
Old 05-04-2014, 12:12 PM   #9
LS3 SS
Drives: 2010 Cyber Grey Camaro SS (LS3)
I had this SAME problem, and had to learn the hard way.
I stalled my car in the burn box atleast 6-7 times before I realized my tires have to be really wet.
I have 305/45/18 MT ET Streets, so what I started doing, is making sure a buddy, or the burn box guy sprays lots of water before I run. If you have to ask him to, make sure you ask him, otherwise they will treat you like everyone else does.
Other than that, just rev it up to about 4k or so, and once you dump it, let the tires spin for just a half second, and then hit the brake.
LS3 SS is offline   Reply With Quote
Old 05-04-2014, 07:19 PM   #10
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
If it is hot and windy and the track attendant is not keeping the box watered down I can stall my car with the line lock on and dumping the clutch. If I heat the tires well (3-5 seconds) and keep them at 17 psi it will not spin at all in first gear. That is with 835whp on M&H drag radials. It will run 1.5 60ft times all day.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
