Old 05-03-2014, 07:36 PM   #1
6bangerBOOM
6bangerBOOM's Avatar
Drives: 2016 1SS SW
Naturally Aspirated 3.91 1/4 mile passes. Finally.
[note: I'll post my tickets tomorrow. Right now I'm nursing a major sunburn in a crappy Baytown hotel].
Well I finally made some passes with the new gearing... And I was a little shocked. I knew I was going to fall a little flat towards the end of the strip, but I was hoping I would have made some better times. Granted I only made five passes and I didn't pull my sub box (wanted to know what it does as is). I'm sure I could have gotten a little lower, but I'd like to get a Honda beater in the garage before I really get hard on the car.
My best time was a 14.337. That's with K&N cai, Vmax TB, Falken 315's on my rear tires, and a custom tune from Lucky's Speed & Performance.
The car pulled hard in the first 1/8 mile, but just ran out of pull by the end. I will note that I was scaring the hell out of SS's in the 60' as I was hitting that around 2.1sec. Anyways, looks like it's a good thing I still have that Zex kit in storage.
Update: time slips in order slowest->fastest. I was car 128... Obviously lol
6bangerBOOM is offline   Reply With Quote
Old 05-03-2014, 08:13 PM   #2
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Drives: 2011 2LT/RS Camaro IOM
Interested to see your times since I just bought a set of 3.91s that I need to put in.
kjkjr27 is offline   Reply With Quote
Old 05-03-2014, 08:13 PM   #3
BlackoutLFX
BlackoutLFX's Avatar
Drives: 2012, Black 2LS
good stuff. I need to get to the track.
Nytrex 100 hp nitrous triple threat system, NytrexAccu-pressure bottle heater, HP tuners, K&N Typhoon CAI, MACE 6mm MI, Solo Performance high flow cats, Flowmaster American Thunder cat back exhaust system, BMR subframe connectors, BMR tunnel brace, BMR lowering springs, BMR Xtreme Anti-roll bar rear, Hotchkins Strut brace, SS/LS3 3.45 LSD, Axles, and hubs, Elite Engineering catch can, B&M Supercooler transmission cooler, FTI 3200 Stall.
BlackoutLFX is offline   Reply With Quote
Old 05-03-2014, 08:59 PM   #4
6bangerBOOM
Drives: 2016 1SS SW
No, you need to get the damn Mace cams figured out so the rest of us can get'em!
Old 05-03-2014, 10:17 PM   #5
AshenGreyLFX
AshenGreyLFX's Avatar
Drives: 2014 Ashen Grey 1LS
That seems a bit high for that set up. I drive a 14 1ls and best run was a 14.170 @ 97.71 with a 2.70 60' speed. I know you can do better if you get the right climate and launch conditions. Will post slip shortly if desired.
AshenGreyLFX is offline   Reply With Quote
Old 05-04-2014, 04:14 AM   #6
6bangerBOOM
Drives: 2016 1SS SW
I'm sure I could too, as it was getting faster with every run, and I'm still a newb to drag racing, so I'm sure a better driver could have done better in it as well. Taking the sub box out probably would have seen a 5 hundredths change, but the biggest thing hurting me was 4th gear. The before and after of this upgrade is where and how the car hits it's powerband. The stock sixxer's were in the full throws of their power band right as I was coming to the plateau of mine.
Old 05-04-2014, 11:44 AM   #7
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
What were you trapping at?
Old 05-04-2014, 12:36 PM   #8
6bangerBOOM
Drives: 2016 1SS SW
Update: pics posted. A couple 97's and 96's and my first run of the day was 14.7 sec at 94mph
Old 05-04-2014, 12:39 PM   #9
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Where you starting in first gear?
Old 05-04-2014, 12:49 PM   #10
6bangerBOOM
Drives: 2016 1SS SW
Yep. Automatic, so it was just mash n' go.
Old 05-04-2014, 12:55 PM   #11
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Awesome that was one thing I was wondering about when i do the upgrade, traction issues. Seems like you didn't have too much trouble on street tires. Will have to see how I do since I have more bolt ons and will be using DRs.
Old 05-04-2014, 01:37 PM   #12
6bangerBOOM
Drives: 2016 1SS SW
Yeah, my first pass was without a burnout (14.7) and the rest were with one. So there was a little slippage, but I feel like it wasn't much. I'm wondering what I can do next other than the N2O to make it faster. I hope the Mace cams thing smooths out as that'd be an awesome way to get some power.
Old 05-04-2014, 01:48 PM   #13
AshenGreyLFX
Also, I take out my spare tire as well. I also run between 29-30 lbs in the rear tires and about 36-37 in the front.
2014 1LS / injen short ram. Everything else is stock.
73' Camaro LT 400 SBC De-Stroked.
Old 05-04-2014, 01:51 PM   #14
6bangerBOOM
Drives: 2016 1SS SW
Yeah I was 34psi all the way around. I still have a long way to go.
