![]() ![]() Drives: 2010 2SS Join Date: Sep 2012
FS: Stock Driveshaft, Axles, trailing arms, toe rods, LCA's
13,000 ish miles. 2010 SS manual drive shaft, axles, front and rear sway bars with endlinks, toe rods, trailing arms, Lower control arms. all in good shape. make an offer.
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
