![]() Drives: 2014 camaro zl1 Join Date: Apr 2014
Zl1 suspension upgrade
Has anyone upgraded the suspension system of zl1.
Saw new sway bar and spring upgrade by eibach. Pls share your thoughts on this matter. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 20 X3M CP & 19 ZL1 1LE A10 Join Date: Jun 2013
The car is a handling champ and a magazine darling in that regard. I would spend money elsewhere. Money on power comes to mind.
🔺22 RS E TRON GT
🔺21 Model S Plaid |
![]() ![]() Drives: 2013 Camaro ZL1 Join Date: Nov 2012
The only thing I'm replacing are the trailing arms and tie rods from BMR. Doing so to eliminate any possible wheel hop when I do end up getting stickier tires.
13 ZL1 A6
LSX 427 with AGP Twin Turbos, E85 and Flex Fuel. Built and tuned by ADM Performance 1000rwhp |
![]() Drives: 2014 CRT ZL1 Join Date: Jun 2013
Upgrade for what purpose ?
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 ZL1 M6 Join Date: Oct 2013
Based on what I have looked at under my car.
There is about 1/2 of an inch available drop before the suspension geometry camber gains would be reversed. As the cars sits stock the control arm is higher at the body pick up point and lower at the ball joint end. This results is a negative camber gain as the suspension compresses, and a loss as the other wheel extends. During cornering this aids to gain the largest contact patch and traction. If lowered too far the arch the lower control arm would reverse the geometry and the opposite of desired effect would pull the camber towards positive as it compresses, and more negative as extended. |
#6 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
The only suspension upgrades I have are the solid subframe mounts sold by ADM. I have never experienced any wheel hop of any kind and have a 1.4x second 60 ft time.
The solid bushings increase noise and vibration when crossing railroad tracks or other hard suspension hits but handling is improved on hard acceleration with no hop. If you race at all I recommend them if all your driving is on the street, stock will be fine.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. ![]() |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 1SS 1LE Vivid Orange Join Date: Mar 2011
There are only so many days in your lifetime. So get out and drive your Camaro...
Dan |
#8 | |
Cartoon Maus
Drives: White ZL1, Chevroyota Prizolla Join Date: Aug 2013
![]() To clarify: I have no idea. |
#9 |
Track > 1/4 Mile
What is your goal with the suspension? Drag racing? Road course racing?
I did the Detroit Speed front & rear sways and front & rear end links. I noticed a large change on the track and I can navigate S turns & chicane's quicker. The sways definitely help if road course racing. Based on a picture that was taken of me last track day braking hard going into Turn #1 I think stiffer springs would definitely help, look at how much the nose is diving!
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
I noticed understeer when pushing the car hard so I installed the adjustable pfadt rear bar with billet sway bar brackets with poly bushings (front and rear) which definitely tightened up the handling.
#11 |
Speed Freak
#12 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
#13 | |
#14 |
| Tags |
| handling, suspension, upgrade, zl1 |
