Old 05-04-2014, 02:58 AM   #1
manumathew
Drives: 2014 camaro zl1
Zl1 cooling upgrade
Hai guys,
Over here in dubai it seems to me that keeping the car cool is more important than increasing the power.
With upgrading the car we void the warranty and pushing the car to its limits are going to result in a sharp increase in temperature as a whole.
My car is stock except for the tune. If I do a run for more than 10 mins the engine oil temperature rises like hell.
What are the upgrades that i can do to keep the car running as cool as possible.
Bigger intercoolers are a given.
any ideas other than that
manumathew is offline   Reply With Quote
Old 05-05-2014, 06:35 PM   #2
ss/rs/378
ss/rs/378's Avatar
Drives: 2012 ZL1 Camaro Victory Red
Cooler plugs,160 degree stat,larger reservoir how warm is your oil temp running are you sure your intercooler pump is working right also it might be in the tune you had done did you have someone tune it or did you us a hand held?
2.55 UPPER PULLEY,100MM IDLER PULLEY,160 STAT,PORTED TB,PORTED SNOUT,MSD PLUG WIRES,NKG PLUGS,KENNE BELL EXTERNAL FUEL PUMP,2"KOOKS HEADERS,HIGH FLOW CATS,3"CORSA 60LB DEKA INJECTORS TUNED BY FROST 580RWHP,571RWTQ.
ss/rs/378 is offline   Reply With Quote
Old 05-05-2014, 09:27 PM   #3
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Ron Davis radiator upgrade
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 05-07-2014, 03:12 AM   #4
BumblebeeQ8
BumblebeeQ8's Avatar
Drives: '14 ZL1 Ashen Gray Metallic
i'm the same situation, i only have a Roto-Fab CAI
ordered a Ron Davis HX, going to order the Ron Davis Radiator and D3PE Reservoir Tank, add T-stat, and will be set maybe add Meth
'14 ZL1 AGM-A6 (SOLD)
BumblebeeQ8 is offline   Reply With Quote
Old 05-07-2014, 08:00 AM   #5
manumathew
My car's oil temp goes to 130 without much effort.
It's already like 40 C over here.
Have an upgraded intercooler pump as the oem broke.
Have talked to my tuner regarding a oil cooler upgrade.
He has suggested to go with the corvette oil cooler.
Also those super chillers has also caught my eye. Donno it wld be practical in this part of the world. Also the water sprays seem to be a gud idea. Has anyone had them installed in there zl1.
Is the oem transmission cooler enough for 45°c...
Old 05-07-2014, 08:01 AM   #6
manumathew
Old 05-07-2014, 08:10 AM   #7
manumathew
Old 05-07-2014, 09:26 AM   #8
Botally Tone
Drives: 2014 Ashen Gray ZL1
If you've gotten a tune that would have already voided the warranty right?
Botally Tone is offline   Reply With Quote
Old 05-07-2014, 10:47 AM   #9
BlackinBlack
BlackinBlack's Avatar
Drives: 2016 Corvette Z06 Blade Silver
Cooler plugs, 160 stat and the larger reservoir are not going to help. First I would ask the tuner to look at fan turn on temperatures and fan speeds. You might be able to tune in turning on the fans on earlier and spin them faster.
Super chiller would just move the temp around. Your issue is not just intake air temperature but the fact that your ambient air temperature is so high. The car as a whole can reject only so much heat in stock configuration.
The best way to lower temps is going to be adding a bigger radiator, an oil cooler and heat exchanger.
If it was me I would by a bigger aftermarket radiator, bigger aftermarket heat exchanger and a bigger aftermarket oil cooler. If you are going to be in heavy traffic or driving slowly I would consider supplemental fans.
I personally would not waste my time with reservoirs either. They add volume so the car will be slower to heat up but if the heat load/ambient temperature is high then you will get high operating temperatures it will just take longer to get to them. Reservoirs are great for compensating for inadequate cooling for short blasts. The same can be said for water/methanol injection. Both are great for drag racing but not great for road racing or street driving.
One other thing. Check your tune. I would make sure the tuner does not have it too aggressive. A leaner tune could mean higher temperatures. Just another thought.
2016 2LZ Z06 Blade Silver
2013 ZL1 BLACK on BLACK <SOLD>
Roto-Fab CAI
2010 2SS/RS BLACK on BLACK <SOLD>
3" MBRP 304 Stainless Exhaust
Roto-Fab CAI
BlackinBlack is offline   Reply With Quote
Old 08-20-2014, 10:25 PM   #10
Rhaar001
Rhaar001's Avatar
Drives: 2013 camaro zl1
what about switching to e85 or running a meth system?
I have heard rumors that when switching to e85 has actually been known to add frost to the fuel lines since it runs so much cooler
2013 Camaro ZL1 Blue Ray Metallic with Rotofab CAI, full flow-master exhaust with x pipe, Stainless Power Long Tube Headers, id 850s, 2.55 upper, 10% lower, 160* t stat
Rhaar001 is offline   Reply With Quote
Old 08-20-2014, 10:27 PM   #11
Oddvious
Oddvious's Avatar
Drives: 2013 ZL1
Meth works just fine as long as you have someone who knows how to tune.
Oddvious is offline   Reply With Quote
Old 08-20-2014, 10:47 PM   #12
JackalopeZL1
JackalopeZL1's Avatar
Drives: 2013 ZL1
I would be surprised if they have e85 in the middle east
2013 Silver ZL1
JackalopeZL1 is offline   Reply With Quote
Old 08-21-2014, 12:21 AM   #13
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
lol...not quite the corn surplus over there that we have here.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 08-21-2014, 08:21 AM   #14
Rhaar001
Rhaar001's Avatar
My bad...i was thinking in general....i missed the dubai part....ik so then meth lol
cooling, intercooler, oil cooler, upgrade, zl1
