Old 05-05-2014, 11:09 AM   #1
zfuzz
zfuzz's Avatar
Drives: 69 Z28 / 12 ZL1
ZL1 on Pfadt or BMR drop springs
Looking for some images of ZL1's on Pfadt 1.2 or BMR 1.0 drop springs. I have searched and found a few but hoping there are some better images out there.
Since dropping the vehicle is rough on the struts has anyone experienced any wear issues with the mag ride? Will it be effected like your typical strut ?
Thanks guys
zfuzz is offline   Reply With Quote
Old 05-05-2014, 12:55 PM   #2
13ZL1BLove
Drives: 2013 Camaro ZL1
I'm lowered on BMR 1.4" kit. Ride is amazing, handling even better, no clearance issues whatsoever. And as long as you correctly install the springs and adjust the camber and toe to as close as stock you shouldn't have any abnormal wear.
2013 Summit White ZL1
13ZL1BLove is offline   Reply With Quote
Old 05-05-2014, 04:13 PM   #3
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Here is 2011Black2SS's ZL1 on the Apex/Pfadt 1.25" springs. They have been on for about a year now and no issues. The car rides and handles very well. I am sure he will be along to provide his own feedback.
Old 05-05-2014, 10:10 PM   #4
mmarx82
mmarx82's Avatar
Drives: '12 ZL1 #1609
I have the PFADT springs on mine and a friend has the BMR springs on his Z and they look like the ride height is the same when side by side. You shouldn't have any probs with the mag ride as long as you don't cut the wires to do the work. Additionally the ride height sensors are self adjusting so there will be nothing to do in that area.
Life is too short to drive cars that suck.
My build Thread
mmarx82 is offline   Reply With Quote
Old 05-08-2014, 07:03 AM   #5
2011Black2SS
Drives: 2017 ZL1 M6
I am running the Apex/Pfadt and I have had no issues so far with over 6000 miles on the car with the springs. To me, it feels like the stock ride, but with a more aggressive look. I also have done one track day and the car handled great on the different track mode settings. I did put it on mode 5 for the most part though. I don't have any problems with normal speed bumps, but I do hit them at an angle out of habit from my other cars. Overall, I am glad I went with Pfadt.
Below are a couple more pictures.
2017 Nightfall Gray Metallic ZL1 M6
2014 Black GMC Serria Z71
1996 Red Z28
2011Black2SS is offline   Reply With Quote
Old 05-08-2014, 10:08 AM   #6
on3wego
on3wego's Avatar
Drives: 2014 zl1 triple black
Clean looking ride. Where did u get the hid's or whatever on ur running lights.. I know the part number is a psx26w or somthing like that and can't find any aftermarket bulbs like silver star or anything for them. I hate the mismatched blue headlights and the yellow running lights underneath
on3wego is offline   Reply With Quote
Old 05-08-2014, 11:03 AM   #7
zfuzz
zfuzz's Avatar
Beautiful cars guys and thanks for the responses. One last question when doing an "even all around drop" either 1 inch or 1.2 inch does the rear appear lower than the front?
A couple of the images make it appear that way but it is probably just the angle of the camera.
Old 05-08-2014, 11:05 AM   #8
Apex Motorsports
With our springs it is pretty even, the rear may even be a tad higher. Of course that also depends on how much junk you have in the trunk.
Old 05-08-2014, 11:26 AM   #9
zfuzz
zfuzz's Avatar
Perfect that is what I would like
Old 05-09-2014, 12:45 PM   #10
subzero05
Drives: 2010 tbd
might want to check out Hurst. They are releasing springs early June for our cars. I just installed the proto's on mine the other day and so far they are great!
subzero05 is offline   Reply With Quote
Old 05-09-2014, 08:36 PM   #11
Apex Motorsports
Great! Hit us up when you are ready.
Old 05-14-2014, 12:10 AM   #12
2011Black2SS
Drives: 2017 ZL1 M6
I got them from gen5diy or 2ssrs on the board I think. Should be in the vendor section.
1996 Red Z28
Old 07-24-2014, 12:17 PM   #13
William.23
William.23's Avatar
Drives: 2011 Summit White.
Question, If I were to get 1.2" drop springs by BMR Front/Rear would I need to change the camber and toe? I'm running with 275/40/20 9.5" front and 10.5" Rear 295/40/20 (Not a ZL1)
William.23 is offline   Reply With Quote
Old 07-24-2014, 12:26 PM   #14
crabapple
crabapple's Avatar
Drives: '12 ZR1
I'm lowered on Apex/Pfadt 1.25" springs....Love the ride and look. 2000 miles and trouble free......
crabapple is offline   Reply With Quote
