Old 05-06-2014, 10:50 AM   #1
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Mylink Install
I will add info on the install here.
If you need any help post up will try to get to this 2 times a day till its done.
Old 05-06-2014, 11:02 AM   #2
USCAMARO14
USCAMARO14's Avatar
Drives: 2LS 2014
Thumbs up
COOL! THANKS!!
USCAMARO14 is offline   Reply With Quote
Old 05-06-2014, 11:06 AM   #3
AlexM
AlexM's Avatar
Drives: Used to be 2012 Camaro 2SS/RS L99
BEE used to have
MyLink with NAV
Black 10 spoke FR41 wheels (ZL1 Replica)
Roto-fab CF CAI / Scoop and Washer Bottle Relocation KIT
Vmax yellow painted ported TB
Solo HF Cats with Kooks 2.5" catback
SLP Replica Spliter, CF Stripes and CF bowties
Hawk ceramic brake pads
OEM Strut Tower Brace - Yellow Plastidip
Range device - AFM Delete
Halo/DRL Harness (Halo/DRL on day and night while driving)
Engine Cover/Air Compressor Delete
AlexM is offline   Reply With Quote
Old 05-06-2014, 11:26 AM   #4
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
subscribed. This is something I think I need to do...
Old 05-06-2014, 01:46 PM   #5
solo3445
solo3445's Avatar
Drives: My SS2................
Nices.......
Sent from my SPH-L900 using Tapatalk
solo3445 is offline   Reply With Quote
Old 05-06-2014, 04:35 PM   #6
Edwin320
Drives: 2018 Camaro ZL1 Convertible A10
Subscribed.
Ed 2018 ZL1 A10 'Vert
Edwin320 is offline   Reply With Quote
Old 05-06-2014, 06:05 PM   #7
firemedicz
firemedicz's Avatar
Drives: '13 ZL1, '69 Z28
So what if you had a 2013 dash and a 2010 center console, any trimming then?
2013 ZL1 IOM, ADM ZL-750 700.53HP/ 681.83TQ
firemedicz is offline   Reply With Quote
Old 05-06-2014, 06:28 PM   #8
2SSRS@Gen5diy
You still need to trim the 4 pack trim, where you trim you dont see its the front end where it meets the dash first, see you cant raise the 4 pack trim as high as with the old radio face, so it will not go in if you dont trim to fix the trim.
1 more thing to fit it in with an auto car you will need to pull out 1/2 way the 2 parts on the trim, or they will scratch the auto shifter trim.
Old 05-06-2014, 10:05 PM   #9
Scourage
Syntax Error
Scourage's Avatar
Drives: 2010 Camaro 2SS/RS
Yes, that's a tighter fit than when it came out. Took a little pressure since it has to clear the bottom of the traction control button and lighter socket, since the lighter socket was deeper, I swung it to the right to clear it first, then all was good.
Scourage is offline   Reply With Quote
Old 05-07-2014, 08:53 PM   #10
Fieryfight
Fieryfight's Avatar
Drives: 2011 Camaro 2LT IBM Convertible
Is there any mainstream stores like RadioShack or autozone that carry the pins that are used in the onstar x2 harness because I managed to break the pin connected to the silver wire and need to find another
...........................................2011 2LT IBM Convertible
Fieryfight is offline   Reply With Quote
Old 05-07-2014, 10:29 PM   #11
Toasty
Custom User Title :D
Toasty's Avatar
Drives: 2011 Summit White 2LT/RS
It's not likely that you'll find them locally. Either get more from GEN5DIY or order the following from your dealer: 13575548 This should be the connector with a lead wire on it. (I think you actually get a pack of 5)
Toasty is offline   Reply With Quote
Old 05-08-2014, 01:00 AM   #12
Toasty
Toasty's Avatar
Originally Posted by Toasty View Post
Got my box today too. I read through the instructions and the only thing that had me scratching my head in confusion is the splitter/antenna cables... all the mismatched colors, etc. Hopefully the videos make it more clear. If not, I might suggest numbering the connectors in the future
So after watching the video, I actually took the cables out of the packaging and thought through the process, and was able to observe that the cable connectors are now color-correct for where they go. Maroon, grey, pink, blue, etc. - so don't mind the colors in the video or picture in the instruction for the connectors, just match up the colors and it will be good.
Old 05-08-2014, 05:17 PM   #13
45th SS
45th SS's Avatar
Drives: 2012 45th anniversary SS
Installed and the radio works great, still working on getting the backup camera on the my link with the splitter to work. Instructions were great and easy to understand. Thanks
***I did not have to Dremel the piece behind the radio nor the 4 pack gauge cluster, everything fit perfectly.. I have a 2012 45th if that makes a difference.
45th Anniversary. Borla LT(catless), Borla S type, CAI intake and Rhino79 installed whipple 2.9L, alky meth kit, 102mm throttle body , GPI tune, VVT custom competition cam, 416ci stroker, forged internals.
45th SS is offline   Reply With Quote
Old 05-08-2014, 08:26 PM   #14
BLACKCAMARO2SS
BLACKCAMARO2SS's Avatar
Drives: 50TH ANNIVERSARY 2SS CONVERTIBLE
Im not so lucky I have a August 2011 45th build.
BLACKCAMARO2SS is offline   Reply With Quote
