Old 05-07-2014, 08:23 AM   #1
rforbes
rforbes's Avatar
Drives: IOM SS/RS
Rear overdrive COG belt replacement
There may be a thread on this already, but I could not find it. What is the best way to change out the rear COG drive belt for a TVS2300?
rforbes is offline   Reply With Quote
Old 05-07-2014, 08:59 AM   #2
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
(1) Loosen the set/tension screw at the side of the blower.
(2) Loosen two bolts on the back of the blower between the cogs
You should be able to slide the jackshaft with the serpentine still installed to release the tension on the cog belt. Install new belt.
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 05-07-2014, 09:09 AM   #3
rforbes
rforbes's Avatar
Drives: IOM SS/RS
Great, thanks for your help!
Old 05-07-2014, 09:15 AM   #4
lexlueger
lexlueger's Avatar
No problem.
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 05-10-2014, 08:15 AM   #5
rforbes
rforbes's Avatar
Drives: IOM SS/RS
Ok, I was given the incorrect belt. (too small) Anyone know an aftermarket belt that will fit the overdrive COG? Should be I believe a HTD-600-8M 75 tooth belt but searches have come up empty.
Old 05-10-2014, 08:24 AM   #6
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
This is the belt i run on mine 6008MGT30
Nitroman28 is offline   Reply With Quote
Old 05-11-2014, 08:06 AM   #7
rforbes
rforbes's Avatar
Drives: IOM SS/RS
Thank you Sir! Found it.
