I like hockey
Drives: 2014 1LT Join Date: May 2014
Has anyone upgraded the stock back up camera?
I just bought a 2014 2LT/RS and I gotta say the backup camera on this is not the best by any means. The lack of lines is a disappointment, but to me it just seems a bit blurry and not accurate. Along the lines of objects may appear closer than they really are.
I was just wondering if anyone swapped out the stock camera with a better one using the current wires and stock head unit. |
I know the 2012's have the lines in the backup camera because mine has it but I haven't seen anyone yet do a conversion or upgrade to something better. Maybe you could switch out the 2014 camera for a 2012 but it might not fit because the back bumper is different.
I like hockey
It's weird they would have had the lines before and now they don't.
69 Z11
Drives: 2017 ZL1 vert, 1969 Pace Car Join Date: May 2012
I have a 2013 and the resolution seems pretty good to me. I've installed a few aftermarket cameras and they aren't as good. My 2¢.
![]() Drives: 2013 Crystal Red Tint 2LT RS Join Date: Mar 2013
I don't believe the camera produces the lines, it would be the software, that's probably why the 12's have the lines and the 13's and 14's do not.
2013 Crystal Red 2LT/RS - Gm ambient lighting kit
#6 |
I like hockey
It's in the camera. When I was putting one in my f150 I had the option of with lines or without.
#7 |
Call Me"Doc"
Drives: 2014 2SS/RS 1LE BLACK Join Date: Apr 2009
#8 |
#9 |
I like hockey
What I was saying was I installed a backup camara in my truck and when I did I had the option of having lines or not having lines. They did not ask if I had an aftermarket head unit or a stock. So the radio had nothing to do whether the lines were there or not, it's all inside the camera.
#10 |
![]() Drives: 2013 2SS Join Date: Sep 2013
Looks like it was a patent lawsuit.
http://www.usatoday.com/story/money/...Moa90V_.y3OYPA
#11 | ||
Call Me"Doc"
#12 | |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
From the artical on the back up camera not having the lines it seems like its the head unit that determines if it has the lines.
The Bird is the word! |
#13 |
![]() ![]() ![]() ![]() ![]() Drives: 2023 Camaro 1SS Join Date: Apr 2014
The blurriness could be dirt on the lens itself. Make sure it's clean. Can't assume it's clean even if you've been through a carwash. Take a look at it, clean it up, and see if that improves the image.
If it was my car, I don't know that I'd go to the trouble of swapping out the camera or even the head unit because of a lack of "lines". I don't see backup cams as an essential piece of equipment (however, the NHTSA does...), let alone lines to guide you. Instead, I'd advise/encourage to improve your skill in maneuvering the vehicle in reverse and see if you can do it without the lines. Save money. Bolster skills. |
#14 |
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1 Join Date: Jan 2014
This is my first car that has a back up camera. What are the "lines" you are referring to? What is its purpose?
