![]() Drives: 2010 ABM SS Join Date: Feb 2011
Anyone running the BTR stage 4 cam?
Seems to be a pretty healthy cam and a little easier on the valvetrain
BTR LS3 Stg IV Cam 233/248 .619"/.595" 113+5 Cam Looking for any feedback
Sold 2010 ABM 2SS RS. Kooks, Corsa CB
#2 | |
Geek
I have something close. He spec'd me 231/246 .617/.596 114+4. It's a great cam. I don't have a dyno sheet, but I have gotten 116 MPH out of it at the track. There might be a little more left in it. I'm a bad driver. It drives great around town. It likes to buck a little between 1000-1500 RPM in 4th. Drives like stock everywhere else.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1 x = ~x Last edited by thahemp; 09-17-2014 at 08:52 AM. |
![]() Drives: 2010 Camaro 2SS/RS IBM A6 Join Date: Jan 2012
I am getting the Stage IV from BTR. Should be installed in about a month.
Anyone else have comments on this cam?
BTR N/A Stage IV, LS3 conv. w/ trunion, 3200 Circle D, ZL1 wheels(295/305), 3.91's, Kooks Stepped LTs, SW Retro CB, AirRaid CAI, VMAX TB, SLP UDP, 160 thermo, BMR goodies
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
Mine will be on the dyno Friday assuming that he gets me a replacement cam this week
![]() Drives: VW... soon to be a 1LE Join Date: May 2014
Any other comments on this? Looking at getting one in my 1LE
#6 |
Geek
What sort of comments are you looking for? It's a great cam. Go for it.
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1 x = ~x |
#7 |
Just thoughts on drivability after the install. I take my car to the road track but drive it as to and from work every once in a while.
#8 |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
#9 |
Geek
I put in quite a bit of effort tuning light load driveability. I had to spend a lot of time in the timing tables trying to find the sweet spot. I was able to get rid of most of the bad manners. Mine will still buck a little between 1500-1800 RPM if I'm on level ground or going downhill. Basically any time I'm in that RPM range and just barely touching the gas pedal. I typically just drive a gear lower than I used to. I can cruise parking lots in 1st without using the clutch. Not 2nd. 6th gear starts working smoothly right at 60 MPH.
With that said... I'm on SS 3.45 gears. You will fare better with your 3.91 gears. You may not have any of the problems I had to deal with.
#10 |
Geek
That is a very important part of the equation, but sometimes you don't know if you can fix it until you get in there and try everything. Sometimes it won't go away.
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: E92 BMW M3 Join Date: Oct 2012
Not so sure I would go so big for a road course driven car.
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned |
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS, 2010 Mustang GT Join Date: May 2010
I am running the Stage 4 from BTR in an auto with 3.91 gears and a 3200 stall. Its a great cam that made great power working with Matt@FSP to adjust the tune a little this week to compesate for the drastic weather change from maryland to new orleans. It does buck in the lower speeds but a good tuner should be able to make it work just the way you like. I went with this cam mainly because of the results I have seen in person and my guy Tim@TandTPerformance recommended it as well.
#13 |
That was what I was thinking. Ii fielded the question to BTR and they recommended the IV. My tuner said that there would be some bucking at low RPM's but he could dial it in okay. Sent from my iPhone using Tapatalk |
#14 | |
![]() ![]() Drives: 2012 Camaro SS 45th Anniversary Join Date: Sep 2013
L99 to LS3 conversion with Comp Cam stg 4 - low rpms it bucks, in park, car wobbles...
love itdirveability around town you'll LOVE! hit the highway - oh my it opens up!
~ 2012 SS ~ |
