Old 05-11-2014, 10:06 AM   #1
a7m1
Drives: Camaro SS M6
Exclamation post your hot idle oil pressure (stock ls3)
mine is about 27 psi at hot idle or little less (my gauge is in kpa ranging from 0-500 kpa 250 being the middle 125 is quarter of the gauge mine is between 125 and 250 so i would assume 187.5 kpa or less)
stock ls3 (0 mods)
on higher rpms it goes all the way to 375 kpa(54 psi)
just had oil changed at dealership stock dexos oil i believe the same weight as on oil cap
on a side note my oil pressure increase rather slowly takes considerable amount of time to build up pressure but holds steady pressure on certain rpm, at idle sometimes it flactuate a little
please post your hot idle oil pressure, oil and weight and any other concerns or thoughts
a7m1 is offline   Reply With Quote
Old 05-11-2014, 11:21 AM   #2
Avenging Orange
Avenging Orange's Avatar
Sounds like you have no worries......normal. I have used 15w40 and 0w30 and the pressure is the same. Oil pressure will seem stronger after oil changes.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 05-11-2014, 08:23 PM   #3
a7m1
can you tell me what idle oil pressure using stock oil that where problems begins?
lowest safe idle oil pressure? hot oil for sure
my car has less than 7k kms
Old 05-11-2014, 09:31 PM   #4
christianchevell
old school chevy rodder
christianchevell's Avatar
just so you all know are cars engines the ls3 is designed to run 30 weight, heavier oil may starve the top end.......... and the stock melling is for 30 weight, and I run about 30 give or take hot and that's good. I used to run small block chevys with high volumes and it would go down to 20 and worry me but never gave a problem on any of the engines. Of course cold the oil pressure with a stock oil pump and my cam is way up there until it gets hot.
Old 05-12-2014, 04:59 AM   #5
a7m1
light oils are rare here, they used the factory oil dexos
however ii use 20w50 for top ups
Old 05-12-2014, 10:26 AM   #6
Denis
Denis's Avatar
Drives: 2010 SS
just did my oil change this weekend. Mobile 1 5W30.
idle -
Old 05-12-2014, 05:52 PM   #7
a7m1
@Denis thats way much higher than my pressure
my pressure gauge has this
0 to the left
250 in the middle
500 to the right
with 2 more splitters making it
0 125 250 375 500
mine is between 125 and 250 kpa probably half the distance and a little less
so i would guess 187.5 to 156.25 kpa which turns to 27 psi and 22 respectively
my car is drivin very softly without abuse
also our temp here is higher my oil temp reach a little higher than 100'c roughly 220'f while your picture its still below 200'f (was your car fully warmed up?)
thanks for your input
Old 05-12-2014, 07:51 PM   #8
Denis
Denis's Avatar
Drives: 2010 SS
It probably wasn't 100% warmed up. My drive to work is pretty short haha
Old 05-12-2014, 08:06 PM   #9
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Mine is like 28 at hot idle. Now I'm going to have a complex Denis.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 05-12-2014, 10:07 PM   #10
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
Post a pic of it at warm idle if you can. If it is really hot it still should be right around the middle maybe just a little below but not much.
MODS:
Old 05-12-2014, 10:50 PM   #11
SS Blinder
SS Blinder's Avatar
Drives: 2011 SS (Sparrow Spearer???)
Heres mine after running errands this morning about 80F and 90% humidity
Black magic woman, don't turn your back on me baby!
SS Blinder is offline   Reply With Quote
Old 05-13-2014, 12:02 AM   #12
J-vette
Drives: '14 1le
Do not run heavy weight oil, the clearances are very tight & running heavy oil could cause damage.
I've only seen Dexos approved oil in 5w-30 & I think 5w20.
J-vette is offline   Reply With Quote
Old 05-13-2014, 07:42 AM   #13
a7m1
i think i am running factory dexos (dealer oil change) and its the same weight that on the cap
ss blinder my pressure is just about less than yours
i will take a picture soon
Old 05-13-2014, 08:19 AM   #14
Denis
Denis's Avatar
Drives: 2010 SS
HAHA like i said, it wasnt 100% hot yet. im sure it dropped 1-2 psi after that pic. dont worry.
ls3, oil pressure, psi
