![]() Drives: 2012 Camaro ss/rs Join Date: Oct 2012
Best gears for 2012 ss?
What do yall think is the best gears for a 2012 ss m6 daily driver? 3.73?
And where would yall recommend getting them from? |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
3.91
I say move atleast a half a ratio or leave it as is. Now if your replacing the whole rear like a new 9" upgrade or ZL1 diff then do what you want.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
I have a 2013 l99 and went with 3.91's plus a circle d "2c" stall. Then grin on my face is permanent when driving!! Hope that helps ya.
![]() Drives: 2012 2SS 45TH Anniversary Join Date: Mar 2012
3.91 gears here...huge difference from the stock ones.
I also recommend a short throw shifter, either the factory 1LE/ZL1 or the MGW (I just put that one in). |
Drives: 2014 SS Join Date: Jan 2011
#6 |
The GM 3.91 gear upgrade is a heck of a deal, especially when you look at other gear sets. Very popular mod.
Best regards, Tyler 888-308-6007 |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 2SS M6 Join Date: Jun 2013
AAM 3.91s I only lost 2mpg and it made a big difference.
#8 |
Another vote for 3.91. By upgrading the stock M6 equipped Camaro SS to 3.91s you will realize an equivalent torque gain of approximately 13% or 55 lb.-ft. of torque. It really helps get these big cars moving faster. And if you get the GM 1LE 3.91 kit and have a Chevy dealer install it you will not impact your warranty.
