Old 05-13-2014, 05:42 PM   #1
roosnam007sag
roosnam007sag's Avatar
Drives: 2012 45th Anniversary Edition
Service theft deterrent system on DIC
Has anyone else had this issue ?
When I tried starting the Car this evening, it just wouldn't start.Never had this issue before . Finally I managed to get it started after couple tries, but this message was displayed on the DIC.
Also the light corresponding to this was ON.
Car's got a canned tune from diablo sport, hence worried about taking it to the dealership.
If any one has had this issue or know about it please provide some info on it.Mainly I am hoping to avoid taking the car to the dealership for this issue.
roosnam007sag is offline   Reply With Quote
Old 05-13-2014, 07:42 PM   #2
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
You do the crime you have to do the time.....
Mods:
Old 05-13-2014, 07:57 PM   #3
Tara Martin
Loves Camaros
Tara Martin's Avatar
Drives: Red '79 Z28, '24 Blk A10 ZL-1 Vert
It may not be related, but I had the same issue on a police package 2005 Chevy Impala. The "Security" light would flash and you'd have to wait ten minutes (time it next time) and then the car would start. It was the ignition switch and the Chevy dealer fixed it twice under warranty, but it started failing again around the time I was retiring, so I didn't care anymore.
Tara
Old and new, sharing space!
Tara Martin is offline   Reply With Quote
Old 05-13-2014, 11:55 PM   #4
Dubscamaro
Living Life in MPH.
Dubscamaro's Avatar
Drives: 15 Summit White 2SS 1LE
Most likely a lose wire somewhere in the KARR system. Call up your dealer.
Dubscamaro is offline   Reply With Quote
Old 05-14-2014, 10:36 AM   #5
TheSmokingSuns
TheSmokingSuns's Avatar
Drives: 2017 Camaro 2SS, 2011 Camaro 2LT
Maybe someone tried robbing your car overnight.
TheSmokingSuns is offline   Reply With Quote
Old 05-14-2014, 12:53 PM   #6
roosnam007sag
That was what came my mind first.Gladly that wasn't the case.
Old 05-14-2014, 12:55 PM   #7
roosnam007sag
Saw the solution from the Cadillac forum , where someone had the same issue and the reason turned out to the accumulated grease and dirt on the key.Cleaned it up and tried starting again.the issue seems to be resolved , no more messages in DIC.
Old 05-14-2014, 10:14 PM   #8
Tbar
Tbar's Avatar
Drives: Silver 2012 LFX
This happened to me once about 2 months ago. No problems since, as I toggled thru the menu all readings were o for voltage, tire pressure, coolant temp etc. After seeing your explanation I realized Sometimes I will scratch inside my ear with a key if I got a itch. Perhaps I did that and got some wax on it. Feel better know that I might have an explanation.
Tbar is offline   Reply With Quote
