22 years of slammin gears
Heat shield removal??
Has anyone removed the rear heat shield by the gas tank and had any problems? (driveshaft is rubbing on it and making horrible rubbing/vibration noise). Yes I've already tried to bend/shape the heat shield to not rub.
I have removed the front one that goes between the driveshaft and exhaust a long time ago with no issues, just wondering about the rear one because its right by the gas tank. Anyone had any problems with it removed or should I leave it? Really want to take it off but not sure about the risk. ![]()
2010 1SS/RS-M6 > SIM w/matte black stripes.
Engine/Performance> Magnuson TVS2300 @ 8lbs-Hennessey CAI-SLP 1 3/4" longtube headers w/ HF cats X pipe SLP Powerflow muffler-QTP dual oval electric cutouts-ZL1 fuel pump-RX catch can-ADM race air scoop,WW relocate-Hurst short throw shifter- Tuned by: Boost Performance 550rwhp/538tq. Drivetrain> DSS 3.5" aluminum ds-Street Slayer Twin Carbon-IdealG master cylinder-Tick ss clutch line&speed bleeder-GFORCE 1500 Outlaw axles-JRE rear end pkg(LPE 3.70's,true trac,billet main caps)-LPW rear cover-Nitto NT05's. Suspension> Minor stuff/bushings |
KaBoom1701
Is your car lowered?
I would not remove a factory heat shield next to a gas tank. lol
Mods:
Not advisable.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
Lol I dont want to either...but its rubbing the crap out of the ds. Thinking about trimming it idk. Nope not lowered
Should add I have aluminum one piece ds not the stock shaft
#6 |
![]() ![]() ![]() Drives: 2013 Camaro 2SS/RS BRM LS3 Join Date: Jan 2013
I think your screen name is ironic because of this thread.
#7 |
![]() Drives: '14 1le Join Date: Jan 2014
#8 |
Boosted Moderator
Mine has been off the car for three years... Making lots of power, and tons of heat... No issues... I'm not saying to remove it, but mine is long gone... 4" one piece driveshaft...
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
#9 |
![]() ![]() Drives: 2010 SS Join Date: Aug 2006
Before removing the shield that's what I do.
POW/MIA - YOU ARE LOST BUT NOT FORGOTTEN IN SOUTHEAST ASIA
#10 |
Take it to your local Chevy service manager and ask him/her if it would be okay (safe) to remove it. Maybe they'll be straight up with you since you (I assume) are out of warranty.
Did this issue start when you put the non-stock drive shaft on?
#11 |
![]() ![]() ![]() Drives: 2014 camaro ss ,1967 chevelle ss, Join Date: Sep 2013
plastic gas tank without any protection from heat, sounds like a good idea.
don't forget the marshmallows.
#12 | |
#13 |
Might be worth contacting Dynamat and ask if this would work http://www.dynamat.com/automotive-an...dio/hoodliner/ .
#14 |
